Painting Steelies
I want to paint the 13-inch steelies on my 1996 CX hatch to black.
How hard is it?
Is it basically, remove all four wheels from the car, clean the steelies, paint the steelies, let dry and reinstall?
It doesn't have to be a flawless job because I have wheel covers too.
How hard is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu9000 »</TD></TR><TR><TD CLASS="quote">if you want the paint to stick, you need to sand, primer, then paint.
if you just clean then paint, the paint will fly off at 30 mph (a little exaggeration) but you know what i mean</TD></TR></TABLE>
It will take more time to sand it and prime it, but it's so worth it. Also, I'd recomend a clear coat on it to protect it, dunno if you want to because of the covers, but ya know
just get some flat black paint and go at it. i didnt take nothing off or sand anything i just cleaned them and painted them it took about a can or 2 and i havent had any probs with mine and its been almost 2 years
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenpowered »</TD></TR><TR><TD CLASS="quote">Did you sand it and prime it? Because I am wondering if I need to do that or not.</TD></TR></TABLE>
If you want it done properly, do both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">easy
Really easy! Clean the wheels good use a wire brush to get off the stuck-on crap.
Mask off the tire once everything dries off, apply primer if you want to.
Spray paint until you have the desired amount/look.
</TD></TR></TABLE>Really easy! Clean the wheels good use a wire brush to get off the stuck-on crap.
all i did was take the wheels off, roll it to my backyard, spray flat black on them. and let it dry. i was super lazy and it turn out great and hasnt peel or chip off for about 1 year in california hot weahter
paint i use was rust olum(or som **** like that from home depot) flat black.
