Need suggestions on how to launch my car
Old Aug 22, 2006 | 05:35 AM
otto's Avatar
Default Need suggestions on how to launch my car
I have an 89 CRX with a b16/turbo. Car makes about 275whp. It has a full-race traction bar and some cheap stock size tires. I have Neptune and a 2 stage rev limiter. I'm afraid to launch the car with the rev-limiter. I fear the car may break if I do. Should I be worried? I'm using stock axles from an integra. Thanks for any help H-T!!!!!
Old Aug 22, 2006 | 06:46 AM
surfingsk8r's Avatar
you could try to preload the drivetrain as your on the two step but your clutch will wear faster is you do, however it should keep you from breaking axles if your worried. personally if it was me i ran stock axles for a while back in the say and i never had any problem launching with 23 inch slicks at about 6k so who knows.
Old Aug 22, 2006 | 10:23 PM
RaceProfessor's Avatar
Default Re: Need suggestions on how to launch my car (otto)
I felt the same as you until I learned to preload. It's not foolproof but drasticly reduces drivetrain shock.
Old Aug 22, 2006 | 11:11 PM
Hondoctors's Avatar
I've always let out the clutch pedal at a steady pace, not too fast but not too slow either. Kept rev's up around 6500 on 24.5" slicks.
Old Aug 23, 2006 | 04:46 PM
Garage 808 Hatch's Avatar
idk, i side step at 7600 on stock axles. boosted b16 making 463whp
aztecracer1
Dec 11, 2008 02:52 PM
bbrian
Apr 27, 2006 02:42 PM
alexsracing
May 23, 2005 02:42 AM
sleeping_sedan
Mar 13, 2005 01:33 PM
18gLUDE
Feb 8, 2004 09:26 PM
