Hondata IM gasket owners, what did your torque your bolts down to?
Old Aug 22, 2006 | 05:34 AM
Dave_B's Avatar
Default Hondata IM gasket owners, what did your torque your bolts down to?
Just as the topic title says. I'm going to be installing the Hondata IM gasket this week and was wondering what torque specs you used? Factory specs, or a little more? TIA
Old Aug 22, 2006 | 05:51 AM
RagingAngel's Avatar
Default Re: Hondata IM gasket owners, what did your torque your bolts down to? (Dave_B)
I went with "feels good to me...."
not that I'm not all for proper torque specs, but I just didn't have a torque wrench with such a low rating (from what I recall).... I did this install years ago with the coolant block off option and it's been working great....
till I fawked my endyn catchcan setup and had oil dumping into the manifold for the mega lose.... but that's another story....
Old Aug 22, 2006 | 05:57 AM
Dave_B's Avatar
I just figured with a thicker material in between there, and the fact that you'll be using less threads in the head, I might go with like 3-5 lbs over factory spec.
Old Aug 22, 2006 | 06:05 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">I just figured with a thicker material in between there, and the fact that you'll be using less threads in the head, I might go with like 3-5 lbs over factory spec.</TD></TR></TABLE>
I would go with factory specs, no more or less.
Old Aug 22, 2006 | 06:11 AM
94rs-turbo's Avatar
I just use the "its tight technique"
Old Aug 22, 2006 | 06:31 AM
Eva01's Avatar
Default Re: (94rs-turbo)
Meh, I used factory specs. Two years later, nuts and bolts are still there.
Old Aug 22, 2006 | 06:36 AM
Finland's Avatar
if you're doing this on the car there's no ******* way you'll get a torque wrench in there. Even if you could, you'd have to use either crow's feet, extensions, or universals, all of which will render your torque readings useless.
Because of all that.. I just tightened mine to "feels good to me" and haven't had any problems for 50K miles relating to my hondata gasket
Old Aug 22, 2006 | 06:40 AM
b19coupe's Avatar
I use the wrist torque wrench.
Old Aug 22, 2006 | 07:18 AM
Dave_B's Avatar
I've got a torque wrench that will reach, just wanted to see what you guys were tightening yours to.
Old Aug 22, 2006 | 09:27 AM
BudMan's Avatar
use the wrist-o-matic. Don't overtighten. Instead, add a little blue loctite & call it good.
Quote of the day: "Overthinking makes Dave a dull boy"
Old Aug 22, 2006 | 09:44 AM
Dave_B's Avatar
Default Re: (BudMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">use the wrist-o-matic. Don't overtighten. Instead, add a little blue loctite & call it good.
Quote of the day: "Overthinking makes Dave a dull boy"</TD></TR></TABLE>
LOL. Better to be prepared grasshoppa, than to get caught with your pants down!
Old Aug 22, 2006 | 10:05 AM
Dave-ROR's Avatar
Use an impact gun at 90psi with a compressor that puts out at LEAST 15 SCFM
Old Aug 22, 2006 | 10:08 AM
Dave_B's Avatar
Default Re: (Dave-ROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">Use an impact gun at 90psi with a compressor that puts out at LEAST 15 SCFM
Score!!! You back in town yet man?
Old Aug 22, 2006 | 01:16 PM
Dave-ROR's Avatar
Score!!! You back in town yet man?</TD></TR></TABLE>
Yeah.. @ work.
Old Aug 22, 2006 | 05:00 PM
an2ny888's Avatar
just make sure to retorque it after a few days, mine loosened quite a bit from 17 ft lbs after a week
Old Aug 22, 2006 | 10:35 PM
Soichiro's way@MF's Avatar
Default Re: (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">just make sure to retorque it after a few days, mine loosened quite a bit from 17 ft lbs after a week</TD></TR></TABLE>
x2
Old Aug 23, 2006 | 04:19 AM
diversegsr's Avatar
Default Re: (Soichiro's way)
I also used these from kingmotorsports.com
http://www.kingmotorsports.com...t=469
made it soooooo much easier
Old Aug 23, 2006 | 04:27 AM
Dave_B's Avatar
Default Re: (diversegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diversegsr &raquo;</TD></TR><TR><TD CLASS="quote">
made it soooooo much easier </TD></TR></TABLE>
Hrm, maybe I'll be getting a set of those, along with the header studs. Thanks for the link.
Old Aug 23, 2006 | 04:29 AM
diversegsr's Avatar
I also got the header studs....like them alot......
Old Aug 23, 2006 | 08:25 AM
Mythias's Avatar
Mine actually cracked when I torqued it to factory spec. I wasnt a happy camper. I suppose it was just a fluke though. In the end I went with the outlaw engineering kit since it is much more inclusive and cost me $105 shipped.
Old Aug 23, 2006 | 04:51 PM
an2ny888's Avatar
Default Re: Hondata IM gasket owners, what did your torque your bolts down to? (Mythias)
on an ot note, i'm dissapointed in my im gasket, the manifold is still boiling hot after a long hard drive. guess i was expecting too much from it
Old Aug 24, 2006 | 05:00 PM
jvtec95's Avatar
Default Re: Hondata IM gasket owners, what did your torque your bolts down to? (an2ny888)
You guys can get those threaded studs for quite a bit cheaper from mcmaster-carr (www.mcmaster.com). for cheap hardware and super-fast shipping.
You can also make your own hydraulic hood shocks from the gas springs available there.
Honda-Tree
Honda CR-V & Element
Apr 16, 2014 07:08 PM
honda06si
Honda Civic (2006 - 2015)
Aug 6, 2006 08:37 AM
Syndacate
10
Jul 31, 2006 07:31 PM
Pullig
Feb 26, 2006 06:13 AM
WOTTEG
Jun 4, 2003 05:41 AM
