Misfire, timing or motor mount?
Old Aug 22, 2006 | 04:34 AM
jumai182's Avatar
Default Misfire, timing or motor mount?
I have a D16Y7 with about 180,000 miles on it. My problem is whenever I get out of first it bogs down harder then it used to. Also when Im changing gears the car lurches/jerks back and forth a little. I drive the car locally so with all the frequent stops and red lights, it gets very annoying. Does this seem like the car is misfiring, the timing is off or a busted motor mount. Last time I checked the sparkplugs were ok, my friend had me open the hood and rev the motor and he said everything seemed ok. I dont want to mess with the timing unless I know its that for sure. Please help.
Old Aug 22, 2006 | 05:13 AM
VtecMakesUGod's Avatar
Default Re: Misfire, timing or motor mount? (jumai182)
has ur check engine light com on?
Old Aug 22, 2006 | 05:17 AM
jumai182's Avatar
Default Re: Misfire, timing or motor mount? (VtecMakesUGod)
Yes, but I had it checked and its because of the O2 sensor(installed headers, no cat) But this has been happening before the header swap.
Old Aug 22, 2006 | 06:53 AM
elguluso's Avatar
the jerk is defenitely the motor mount, have you swapped the timing belt at all, you are supoused to do that every 60-70k or so, if you haven't it wouldn't hurt to do it plus you will know your timing will be right then
Old Aug 22, 2006 | 07:01 AM
philosofy1's Avatar
i would have to go with both.
bogging=timing
jerking=motor mounts
Old Aug 22, 2006 | 07:30 AM
jumai182's Avatar
Default Re: Misfire, timing or motor mount? (philosofy1)
Alright thanks guys, Ill make sure to do that. What is an efficient way to check my mounts? I opened the hood and revved so that my friend can look at it but he still couldnt pin point a bad mount.
Old Aug 22, 2006 | 07:34 AM
philosofy1's Avatar
if you have bad mounts you can see them visually w/o revving the motor. your hardest one to see will be the one right under the firewall.
Old Aug 22, 2006 | 08:37 AM
Syndacate's Avatar
I wouldn't say it's the timing because you said 1st gear is working fine. If you can wind out 1st to the redline w/o it bogging then it's not your timing. Either a misfire or an engine mount (most likely a misfire).
carlosd68
Mar 11, 2012 05:50 PM
89 civic si
11
Sep 30, 2006 04:31 PM
sublimenerd
Sep 8, 2006 09:54 AM
swappedcx
Dec 24, 2005 04:11 AM
dirtracer
Dec 30, 2004 07:16 AM
