fs: type r ecu gsr harness omni cm spoon tb gs-r clutch valvesprings voltage stabilizer tsx bmw hid
Old Aug 21, 2006 | 09:53 PM
comteg396's Avatar
Default fs: type r ecu gsr harness omni cm spoon tb gs-r clutch valvesprings voltage stabilizer tsx bmw hid
items listed on ebay
http://stores.ebay.com/jdsctr
JUST SOLD MY CAR. EVERYTHING MUST GO. CAN GET MORE PIXS IF NEEDED.
READ AND ASK ANY QUESTIONS YOU MIGHT HAVE. ALL SALES ARE FINAL,
NO RETURNS OR REFUNDS. MAKE REASONABLE OFFER ON ITEM(S) YOU WANT
98 GSR Valvesprings......................................
between 70k and 80k
Integra Clutch Stage 3...................................
New, complete. inlcude release bearing, pilot bearing, pressure plate.
here is the link for more detail http://www.proclutch.com/applications.html
GSR Timing belt and water pump...........................
between 70k and 80k
LS throttle cable........................................
as pictured
BMW (E46) Hid Projectors........................................ ......... sold
extra holes were drilled when I mounted the projectors to a civic headlights
TSX Hid Projector .................................................. ..........
as pictured
Lexus slim ballast (1 only)............................................. .....
as pictured
Auto Meter air fuel + voltage meter....................................
OMNI test pipe (USDM Version)..............................
Brand New....still in package w/box
Used for less than a month
OMNI Clutch Master Cyclinder ................................
98 GSR aftermarket distributor cap.........................
MSD accessories....................................... .....
Spoon TB................................................ ...
Charcoal canister..........................................
(00-01) OBD2B Integra Type R ECU immobilizer removed......
The CEL will be on due to the immobilizer being removed
(96-99) OBD2A Integra Type R ECU..........................
(96-99) OBD2A Integra GSR ECU.............................
(94-95) OBD1 Chipped ECU.................................. sold to hondafan62269
not a p28 but was converted for vtec. Custom programmed for
my setup which was 98 GSR w/Comptech intake + icebox, Type R TB,
Skunk2 IM, CTR intake and exhaust camshafts + valvesprings,
JDM ITR 4-1 header, high flow cat and 2.5' custom exhaust.
vtec @ 5200; redline @ 8700; CEL shift light @ 8200;
built in lanch control and full throttle A/C cut off
Boomslang OBD2A to OBD2A ECU conversion harness...........
For 96-98 civic or 96-99 integra to run on OBD2B ecu
FMAC-VR voltage stabilizer................................
99 Integra engine harness.................................
complete harness all the way to the firewall plugs
Modified by com-teg at 5:48 PM 10/5/2006
Modified by comteg396 at 9:24 PM 10/20/2006
Modified by comteg396 at 8:39 AM 11/6/2006
Old Aug 22, 2006 | 07:47 AM
comteg396's Avatar
Default Re: fs: type r ecu gsr harness omni cm spoon tb gs-r clutch valvesprings voltage stabilizer tsx bmw
morning after bump
Old Aug 22, 2006 | 12:29 PM
comteg396's Avatar
UP
Old Aug 22, 2006 | 04:57 PM
comteg396's Avatar
up
Old Aug 23, 2006 | 07:17 AM
comteg396's Avatar
up
Old Aug 23, 2006 | 03:26 PM
comteg396's Avatar
TTT
Old Aug 23, 2006 | 04:49 PM
B20inDCinLBC's Avatar
bump
Old Aug 23, 2006 | 05:07 PM
wakeboard_dude5's Avatar
Is the OBD2A ITR ecu USDM? if so, how much shipped to 98275??
Old Aug 23, 2006 | 08:05 PM
comteg396's Avatar
Default Re: (wakeboard_dude5)
the OBD2A ecu is jdm. It is pending sale.
Old Aug 24, 2006 | 03:10 PM
comteg396's Avatar
up
Old Aug 24, 2006 | 04:39 PM
iH8RICERZ's Avatar
check your pm!
Old Aug 24, 2006 | 07:47 PM
LvN's Avatar
LvN
how much for those projectors? Tsx and e46
Old Aug 24, 2006 | 07:50 PM
cryptikman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i &raquo;</TD></TR><TR><TD CLASS="quote">how much for those projectors? Tsx and e46</TD></TR></TABLE>
Old Aug 24, 2006 | 08:41 PM
comteg396's Avatar
e46 is pending, asking $80 shipped to lower 48 states
Asking for $140 shipped for the TSX
Old Aug 25, 2006 | 08:56 AM
comteg396's Avatar
all pm replied
Old Sep 29, 2006 | 04:49 PM
Hatch_Back_97's Avatar
How much for the voltage regulator. My headlights are having major problems with half dimming and going out then coming back on. Does it work like it is supposed to, make drops and such go away?
Old Oct 3, 2006 | 01:45 PM
CRG Motorsports's Avatar
Former Sponsor - Cancelled
pm'ed
Old Oct 3, 2006 | 04:34 PM
GundamONE's Avatar
very interested in tsx projectors...what year is it off of? non-fresnel? let me know! THanks in advance...
Jeff
Old Oct 3, 2006 | 07:40 PM
jcsurfer8386EF's Avatar
From: wudnt u lik 2 no...haha, SO CAL, United States
WHAT KIND/MODEL OF 99 INTEGRA ENGINE HARNESS?
Old Oct 5, 2006 | 01:17 PM
comteg396's Avatar
all pm replied
Old Oct 5, 2006 | 04:54 PM
comteg396's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcsurfer8386EF &raquo;</TD></TR><TR><TD CLASS="quote">WHAT KIND/MODEL OF 99 INTEGRA ENGINE HARNESS?</TD></TR></TABLE> gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GundamONE &raquo;</TD></TR><TR><TD CLASS="quote">very interested in tsx projectors...what year is it off of? non-fresnel? let me know! THanks in advance...
Jeff</TD></TR></TABLE> 03 or 04 model, i forgot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_Back_97 &raquo;</TD></TR><TR><TD CLASS="quote">How much for the voltage regulator. My headlights are having major problems with half dimming and going out then coming back on. Does it work like it is supposed to, make drops and such go away?</TD></TR></TABLE>
sound like you have a bad alternator. The only changes I notice when I had it installed on my teg were..
better idle, better start, and slight improvement on gas.
Old Oct 7, 2006 | 09:17 PM
How much is it I wasked, lol...PM me please, I need this right away!
Old Oct 9, 2006 | 11:28 AM
comteg396's Avatar
Default Re:
all pm replied
Old Oct 11, 2006 | 05:30 PM
hhhmmpphhh
Old Oct 18, 2006 | 09:13 PM
comteg396's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_Back_97 &raquo;</TD></TR><TR><TD CLASS="quote">hhhmmpphhh</TD></TR></TABLE>
pm'd u
