90 Prelude idling problem
Old Aug 21, 2006 | 05:44 PM
rburdge's Avatar
Default 90 Prelude idling problem
I have a 90 Prelude 2.0 SI fuel injected. It has 2 problems at the moment:
1st and foremost, there is no power to the fuel pump. Fuse is good. Car has been sitting for a long time, always started on 1st crank. Thought the pump failed, but it spins when voltage is applied. Can I just run another ignition switched wire from the fusebox to the pump? Is there anything between the ignition and the fuel pump, like a fusable link, relay, other fuse, etc?
2nd, when it idles, it cycles from 500 to 2500 RPM every few seconds. Has done this for a long time, and many attempts to fix it have not resolved it. Any guidance on what to look for next on the idling problem would be appreciated.
Thx!
Bob
FixCarPls
Sep 18, 2016 09:09 PM
akbrewer
Oct 10, 2007 05:06 AM
slazio
Dec 26, 2006 12:53 PM
jwatheyjr
Aug 12, 2005 04:13 AM
ImprtTuner88
Apr 17, 2003 10:55 AM
