h22 with an h23 crank pulley issue
Old Aug 21, 2006 | 05:42 PM
asmallsol's Avatar
Default h22 with an h23 crank pulley issue
I did a swap on a 92 Si and since all the JDM parts didn't look too sound, in addition to keeping ac and I did NOT want to unhook those lines. Once I realized that the thickness of the pulleys were diffrent (one has an extra rib on it) and since I was using the H23 AC PS and alt, I threw the h23 crank pulley on there with the proper belts.
I thought it was good as I drove a maybe 10 miles on it, but while dealling with a diffrent swap issue, I had to rev the car to 3-4k RPM to do the test on the Knock sensor, and when I did that, my PS belt would all of a sudden develope a horrible vibration. I figured it was just a loose belt, so I tightened it up. While taking a closer look I realized my problem
I am using a p14 crank pulley, as well as all accessories. When I looked down at the PS belt, I realized that the PS pump is maybe a few millimeters closer to the driver side then the spot on the crank pulley for it, aka, they are parellel but are not linear with an offset of a few millimeters (yea math terms). This causes the belt to be slightly bent, and I am sure it is putting alot of extra stress on the PS pump and possibly the crank pulley.
So my question, what do I have to do to make this work. Is it just the PS bracket that needs to be changed?
Old Aug 21, 2006 | 06:12 PM
asmallsol's Avatar
Well I tried to use my h23 PS bracket as I am using the P13 one, and realized why I didn't in the first place. There is a huge metal chunk that normally goes into a casting mark on the h23, but that casting mark isn't on h22's so it will not work.
Old Aug 21, 2006 | 06:23 PM
92hondalude's Avatar
Default Re: (asmallsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol &raquo;</TD></TR><TR><TD CLASS="quote">Well I tried to use my h23 PS bracket as I am using the P13 one, and realized why I didn't in the first place. There is a huge metal chunk that normally goes into a casting mark on the h23, but that casting mark isn't on h22's so it will not work. </TD></TR></TABLE>
you have to grind that down then install it and your problem will be fixed
Old Aug 21, 2006 | 06:39 PM
asmallsol's Avatar
Default Re: (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">
you have to grind that down then install it and your problem will be fixed </TD></TR></TABLE>
Do you know from experience or is that an assumeption?
Old Aug 21, 2006 | 07:49 PM
asmallsol's Avatar
Old Aug 22, 2006 | 06:21 AM
asmallsol's Avatar
up
Old Aug 22, 2006 | 06:49 AM
Lewdin' Incognito's Avatar
Do you know from experience or is that an assumeption?</TD></TR></TABLE>
I know of people doing this. While I don't have personal experience doing this, I know that many people have. I know I saw it in at least one write up on here. Is really not that big of a deal, and will get you what you need.
Old Aug 22, 2006 | 09:07 AM
asmallsol's Avatar
Default Re: (Lewdin' Incognito)
alright, to give closer to this thread, I ended up shaving the h23 bracket. Not only is that one large chunk in the way, also the casting is a little thick to fit in the block casting towards the bottom, so you need to shave off the lower corner that touches the block and the alternator bracket.
Old Aug 22, 2006 | 03:56 PM
yes i know this from experience
i did this on my swap
Vilmar
Nov 26, 2006 04:11 AM
paulwithap
Jul 20, 2006 12:42 PM
dreams190
May 17, 2006 02:49 PM
blueBB4lude
May 1, 2006 11:30 PM
4bidden
Apr 26, 2002 06:19 AM
