help on installing manifold
Old Aug 21, 2006 | 12:08 PM
khangman's Avatar
Default help on installing manifold
i put on the manifold but throwing me code 7 and motor blowing white smoke. casue i cant remeber the water line
Old Aug 21, 2006 | 12:11 PM
khangman's Avatar
Default Re: help on installing manifold (khangman)
it a skunk manifold. need help asap
Old Aug 21, 2006 | 12:15 PM
khangman's Avatar
im puting it on d16z. need help asap. after i get help im putting in turbo
Old Aug 21, 2006 | 12:16 PM
G2 Speed's Avatar
Dude stop bumping ur thread
Old Aug 21, 2006 | 01:56 PM
STaNkFaNgaZ's Avatar
Code 7 is TPS, check around that area u might find a loose wire or something...
Old Aug 21, 2006 | 02:24 PM
Syndacate's Avatar
Default Re: help on installing manifold (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">Dude stop bumping ur thread</TD></TR></TABLE>
Man, don't tell him not to bump his thread, if "where to put my JDM sticker" posts are allowed in this TECH forum, a TECH problem like this should be allowed in this TECH forum. This is where he should come if he needs help with an actual tech issue.
At OP:
Well as STaNkFaNgaZ said, it's the TPS code. THe D16Z6 engines are common enough that you can probably find a friend with one, swap the TPS, unplug the backup fuse for 10 seconds, start the car back up, and see if ur still throwing the code. As for the white smoke it could be a variety of things. If a coolant hose isn't hooked up and it's spilling coolant on something hot (like the exhaust) it'll create the white smoke, of course it can be the headgasket. Something's definatley fucked up somplace that's not the mani. Did you take the head off to put on the mani?
Old Aug 21, 2006 | 03:25 PM
cambopheonix56's Avatar
Default Re: help on installing manifold (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
They were 4 minutes apart
Old Aug 21, 2006 | 04:29 PM
suspendedHatch's Avatar
Default Re: help on installing manifold (cambopheonix56)
I don't think he was bumping but I do think he needs to seriously learn how to use the edit button. Oh well, no harm done.
Old Aug 21, 2006 | 04:37 PM
JDM_EjONE's Avatar
man STFU and go play in the street he needed help
Wilka
Mar 20, 2013 10:11 PM
RA61825
30
Feb 16, 2011 07:40 AM
SideFX
Sep 17, 2009 06:30 PM
wolfdawg
Jan 31, 2008 05:47 AM
