FS: 93 Bar'd HB w/B18C1, CHEAP, Car does not run!!!!!!! So Cal!!!!!!
Old Aug 21, 2006 | 11:04 AM
H22a1civic's Avatar
Default FS: 93 Bar'd HB w/B18C1, CHEAP, Car does not run!!!!!!! So Cal!!!!!!
<U><FONT SIZE="5">93 SI HB (primer Blk) w/ Clean title</FONT></U>
<U><FONT SIZE="5">3,000.00 OBO willing to part out for the right price!!!</FONT></U>
<U>Under the hood</U>
Semi Built ref legal GSR/B18C1 swap (<U>bar sticker in door </U>and all paper work on the motor) Stock w/ out parts & tran = 3000.00
Skunk2 Springs = 280.00
Skunk2 Retainers = 170.00
CTR Cams = 400.00
ITR Pistons = 350.00
ITR Rods = 400.00
New Crank = 180.00
New rings = 130.00
New Rod Bearings = 100.00
New Head Gasket = 50.00
AEM Cam Gears = 200.00
AEM C.A.I = 280.00
DC 4-1 = 380.00
2.5 collector and custom 2.5 exhaust (looks stock) = 500.00
ITR Oil pump = 120.00
ITR Water pump = 120.00
aluminum radiator w/ Fan = 400.00
NGK Plugs = 70.00
<U>Tranny</U>
2000 JDM ITR tranny w/LSD (4.78 final drive) = 1700.00
ACT clutch = 350.00
12 lbs fly wheel = 250.00
<U>ECU</U>
Custom chipped ecu with dual maps
(stock or race chip w/ the flip of a switch) = 600.00
<U>Suspension & Brakes</U>
Koni adjustable Dampers = 650.00
Sprint Springs = 200.00
Front & Rear Sway bars = 180.00
(all-around disk)
GSR Front Calipers and rotors = 150.00
Si rear Calipers & rotors = N/A
<U>Wheels</U>
DA rims w/ good tires = N/A
<U>Interior</U>
All stock & clean
Check engine Light lights up as a **** light @ 8,500rpm
Push Button Starter = 80.00
White Cluster face = N/A
Momo hub = 80.00
Momo Competition Wheel = 200.00
Skunk2 **** **** = 40.00
No name Short Shifter = N/A
Acura CD player w/ code = N/A
<U>Exterior</U>
Duck bill wing = N/A
Vision Amber Corners = 50.00
JDM H4 Yellow head lights = 35.00
<U>All prices are for just the parts alone and not including labor coast!!! </U>
Just put in new rings, rod bearings, crank and head gasket It has a clean title and body is strait w/ no major dents but I wouldn't call it perfect, needs paint & some minor TLC. CAR DOES NOT RUN, someone threw a rod bearing or some thing that I havent had time to check out yet on a test drive over the weekend.
Modified by H22a1civic at 12:27 PM 8/21/2006
Old Aug 21, 2006 | 11:18 AM
DUFFM4N's Avatar
Default Re: FS: 93 Bar'd HB w/B18C1, CHEAP, Car does not run!!!!!!! So Cal!!!!!! (H22a1civic)
damn thats cheap...sounds a lil too good to be true...but goodluck
Old Aug 21, 2006 | 11:28 AM
H22a1civic's Avatar
Default Re: FS: 93 Bar'd HB w/B18C1, CHEAP, Car does not run!!!!!!! So Cal!!!!!! (DUFFM4N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N &raquo;</TD></TR><TR><TD CLASS="quote">damn thats cheap...sounds a lil too good to be true...but goodluck </TD></TR></TABLE>
H22a1civic
Aug 21, 2006 10:52 AM
H22a1civic
Aug 18, 2006 02:26 PM
H22a1civic
Aug 18, 2006 02:18 PM
turbociv
Oct 19, 2004 03:15 PM
