what bracket do i need? do i need another bolt?
just had an auto-manual swap done, there are some minor problems
the arrows point to them
what bracket do i need for the clutch line? i tried searching honda parts catalog but cant figure it out
also, do i need a bolt for that empty hole right htere? or is it supposed to be like that?
i read your over thread.....and i understand your pain.
i had a camber kit installed on my old crx many years ago, and afterwards i started working on my own car....and i went over the other guys work and it was horrible (and this was from a shop)
so anyway, i took a picture of my stock clutch line for you..(which include your missing bolt)
wow your clutch line is completely diff than mine!! what year civic do you have?
you also seem to have a ground where i dont
sorry man, its a 94 vx, but this is how all the clutch lines i've seen are, and this is my second eg.
also the ground is the same, take in mind my picture is from a b18c, but it was the same on my sohc.
it also looks like you're missing the ground bracket.
the clutch line runs to the firewall to the passenger side and runs along the wall of the engine bay...not just out in the middle of the bay like yours.
if you want more pictures let me know.
also looks like you're missing the boot on your pressure plate release fork thing.
and do you have a bracket for your slave cylinder?
that's what it should all look like.
looks like you're missing the transmission hanger, clutch pipe bracket, and does your reverse light work?
Casue you have a 96-00 Civic, 92-95 Brackets are different.
You need
46996-S04-000 BRACKET, CLUTCH PIPE (B) $5.50
90651-538-000 CLIP, BRAKE HOSE $2.55
21221-P4A-010 STAY, RR. RELEASE PIPE $8.13
All of that is for the Rear Bracket on the tranny to hold up the clutch line.
Number 16 & 21
Number 4
You need
Number 16 & 21
Number 4
Type-Spaz
Feb 20, 2023 10:39 AM
ewok1
13
Oct 28, 2011 05:56 PM
Pee Wee
10
Apr 23, 2006 11:11 AM
