Right Rear Wheel Heating up!!!
Old Aug 21, 2006 | 09:14 AM
Kagelude's Avatar
Default Right Rear Wheel Heating up!!!
Like the title says the right rear has been getting really hot.. it is possible that my calipers have locked. when i release the Ebrake the car does roll freely. can this hear casue some "worpage" or damage to my rim, TRE, linkage, ect. the pads are new i have no idea what could be causing this, any ideas.
Old Aug 21, 2006 | 09:19 AM
Honda Sport's Avatar
check your brake caliper, I remember my wheel getting hot because my piston was frozen in the caliper...
Old Aug 21, 2006 | 09:22 AM
Kagelude's Avatar
Default Re: (Honda Sport)
would i have to chage the whole caliper or is there a way to fix that
Old Aug 21, 2006 | 09:32 AM
pizzamanprelude's Avatar
Default Re: (Kagelude)
wheel bearing
Old Aug 21, 2006 | 10:27 AM
Kagelude's Avatar
Default Re: (pizzamanprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pizzamanprelude &raquo;</TD></TR><TR><TD CLASS="quote">wheel bearing </TD></TR></TABLE>
I just put a new one of those in there. you think it may be defective. change them with suspension upgrade.
Old Aug 21, 2006 | 10:44 AM
jardolei's Avatar
You might just need to clean the pistons on the caliper of old grease and reapply some new one. Its the first thing to try if one seems stuck and its not expensive
Old Aug 21, 2006 | 10:53 AM
Eddiebx's Avatar
its easy to tell if its stuck, just jack that side up and spin the tire
Old Aug 21, 2006 | 11:33 AM
Kagelude's Avatar
Default Re: (Eddiebx)
got it, thanks guys, i'm going to give it a try after i get out of work. will any machine lube/grease do or would it have to be for brake parts
Old Aug 21, 2006 | 01:39 PM
is it rumbling when your driving?
Old Aug 21, 2006 | 02:48 PM
Kagelude's Avatar
i don't hear anything out of the ordinary when i drive that is why its hard for me to figure out what it is, i'm still at work right now.. i'll be gettin out in about 15 minutes, then i'll jack it up and give it a spin to see if the pistons on the caliper are the problem. i'll keep you guys posted
Old Aug 21, 2006 | 03:14 PM
Mr.60trim's Avatar
From: What Business is it of yours where Im from Friendo
Yea most likely it's a frozen caliper...I went through 3 lately.
After driving around, go back there and notice if there's any brake pad stench.
Old Aug 21, 2006 | 07:56 PM
Chris F's Avatar
Default Re: Right Rear Wheel Heating up!!! (Kagelude)
90% it's a sticky caliper or e-brake release. Could also be a wheel bearing. You can probably lube or rebuild it as needed
Do you see see excessive brake dust? That's a pretty sure sign it's a brake issue.
To make sure it's not a bearing, jack up the rear and check for any play in the wheel by grabbing it top and bottom and shaking it, same side to side, to see if the bearing has play. If it does, re-torque the axle/hub nut but that may not help.
MooreJo02
Mar 17, 2018 02:24 AM
meangreenEG
Aug 9, 2009 09:57 AM
BDogggUT34
Sep 21, 2007 03:04 AM
rice a roni
Jul 2, 2005 07:41 AM
tommymoose
14
Apr 21, 2005 12:08 PM
