TO ALL RICH RUNNING EF D15B2's NEED HELP DIAG
Old Aug 21, 2006 | 07:36 AM
greekgino's Avatar
Default TO ALL RICH RUNNING EF D15B2's NEED HELP DIAG
Ok so heres the deal i just picked up a 90 dx hatchback, and shes running very rich i can see her smoking and i smell the fuel. A full tune up has been done ( correctly ) and shes still running rich.
- I get hard starts ( are the cylinders getting flooded?)
- backfired a couple times right after the engine starts running
- all the old plugs were fouled with carbon
- smokes out the back at idle and while revving
- while revving a black fuely wattery substance blows out of the exhaust (good amount)
from what ive searched this is a pretty common problem, and ive heard of people have replaced the 02 sensors, cats, injectors, ecu's, and still nothing. i was wondering if replacing the PGM-FI relay should be the first step in tackling this problem, and also if the igniter and coil play a role in this aswell
THANKS IN ADVANCE
Old Aug 21, 2006 | 08:55 AM
SFlCrx's Avatar
first i would make sure you are really running rich get the car on a 5 gas machine(sniffer) or hook up a Y band i smell fuel on my car all the time but i'm runnig lean at idle 16;1 a/f so make sure before and adjustments. first step in diagnostics is verfiy the complaint
Old Aug 21, 2006 | 03:56 PM
91SiZ6's Avatar
What's your ignition timing set to?
Old Aug 24, 2006 | 08:29 AM
crazyemokid's Avatar
Default Re: (91SiZ6)
smoking out the back is probably the valve guides, an it sounds like u might also have a bad main seal
Old Aug 24, 2006 | 05:09 PM
godruler's Avatar
Default Re: (crazyemokid)
if its a d15b2 its probrably oil your burning
gary05
Mar 16, 2006 11:03 AM
TeamTooQuick
Feb 9, 2003 09:51 PM
Type R1
Apr 17, 2002 07:39 PM
Steppin Razor
Aug 16, 2001 01:52 PM
