clutch cable
Old Aug 21, 2006 | 07:02 AM
95_red_dc's Avatar
Default clutch cable
I swapped a b18b into my crx and I heard from some places that you need to swap out the clutch cable for a 90-91 integra I never did that is there any differances or problems thqat it is gonna cause thanks
Old Aug 21, 2006 | 07:05 AM
ludesrv's Avatar
You don't have to switch clutch cable you have to switch throttle cable unless you want to rig it up to work.
Old Aug 21, 2006 | 07:30 AM
Loserkidwac's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">You don't have to switch clutch cable you have to switch throttle cable unless you want to rig it up to work.</TD></TR></TABLE>
Old Aug 21, 2006 | 08:11 AM
civicandy's Avatar
Default Re: (Loserkidwac)
10-4 on that one
Old Aug 21, 2006 | 09:22 AM
crxnj's Avatar
yeah you can use the stock clutch cable,but the integra cable gives more adjustment and if you every get an upgraded puck clutch it does help to have the integra cable
Old Aug 21, 2006 | 09:41 AM
95_red_dc's Avatar
Default Re: clutch cable (ls_swaped_crx)
Yeah I have a stage 1 exedy clutch and I have the cable adjusted all the way up and it does not grab as low as i want it to so if i swap it out with a teg cable there will be more adjustment right
Old Aug 21, 2006 | 09:51 AM
Doodoo's Avatar
The key words here are "have to". As stated earlier clutch adjustments are much easier with the Integra cable.
Old Aug 21, 2006 | 11:13 AM
ludesrv's Avatar
Default Re: (Doodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doodoo &raquo;</TD></TR><TR><TD CLASS="quote">
The key words here are "have to". As stated earlier clutch adjustments are much easier with the Integra cable. </TD></TR></TABLE>
I can adjust my clutch fine with my stock cable and ACT clutch on Y1 tranny.
Nutnwrench
Jun 18, 2008 08:55 PM
mjfubar101
Dec 25, 2007 08:20 PM
1RMDave
Jan 27, 2006 04:33 AM
