5 lug question
The rear 5-lug hubs will bolt right up to the CRX trailing arms.
The fronts require '90-91 Civic EX knuckles (to fit the 17CL15VN calipers and to avoid any major alignment and geometry issues) and bearings, and some machine work on the 5-lug hubs is required to reduce the diameter for fitment with the EX bearings.
In addition, if you're using JDM ITR front hubs, you'll have to deal with the 36mm outer CVs. You're on your own there if you're using a D-series with unequal-length axles.
Also, you'll want to upgrade the brake master cylinder to improve pedal feel and the proportioning valve to set the proper braking bias with the new 11.1"F/10.2"R brakes.
WagOvan Man
Feb 28, 2006 02:00 PM
