how to swap a b18b1 (obd1 Ls) in a 91 CRX Si
Old Aug 20, 2006 | 11:42 PM
px_R's Avatar
Default how to swap a b18b1 (obd1 Ls) in a 91 CRX Si
do anyone have any link on how to do this....
any help on the wiring,
can I get the harness from the Ls and put it in the crx?
I need to ref it with the Ls motor any help plz....
Old Aug 21, 2006 | 05:34 AM
Loserkidwac's Avatar
Default Re: how to swap a b18b1 (obd1 Ls) in a 91 CRX Si (px_R)
I have same car and motor as you, he swap is pretty straight forward and easy to do, i stayed OBD0 so if you do you will need a dizzy and ecu, use the stock harness everyhing plugs in fine you only have to extend the wire for the fan switch since the a6 has it on the back of the block and OBD1 motors have them on the thermo houseing
Old Aug 21, 2006 | 09:30 AM
saikouEF8's Avatar
go obd1...if u dont you limit your tuning options. get an mpfi jumper harness, ls ecu, i think i used an si harness and changed the injector plugs when i did it. .... wire in a resistor box...b-motor into ef mounts,b motor into ef linkage teg axels... ull need teg hubs also if u have an hf. i think im right... someone chime in if im not. i have this swap so pm me if u get hung up on something.
Old Aug 21, 2006 | 10:02 AM
Default Re: how to swap a b18b1 (saikouEF8)
It says 91 Si in the title, you won't need to do much to make it work, and OBD0 is fine, if its just a stock motor just run a PR4...if you want to do anything down the road, just chip it and use turboedit, OBD1 conversion isn't needed and cn be more of a hassle
Old Aug 21, 2006 | 01:44 PM
px_R's Avatar
thanks but need to ref the car with the LS,
and the Motor is complete with axle, motor mount, ecu, shift linkage, and everything eles,
do i have to use differnet axle, or anything from other motor?
Old Aug 21, 2006 | 01:52 PM
EFRue57's Avatar
Default Re: (px_R)
you need different mounts. stock integra mounts won't work. go to http://www.hasport.com. they make a very reputable mount kit. you will also need their shift linkage. you can use the axles from an integra. it's also a good idea to get a computer from a 90 or 91 integra. you can use your SI ecu but it doesn't run as well. you will have to extend the fan switch wire as stated before. and possibly the o2 sensor wire if you plan on getting a header. you will also need to use obd0 injectors and distributor. other than that, your si wiring harness is plug and play.
Old Aug 21, 2006 | 02:07 PM
px_R's Avatar
Default Re: (EFRue57)
will i be able to state ref like with ur setup
DA john
15
Mar 23, 2013 12:45 PM
xXhellxraiserXx
Jan 15, 2012 10:23 AM
BLUE EH3
20
Feb 20, 2007 11:31 AM
datnigabluberry
Mar 21, 2006 03:32 PM
HtC_SiR
May 26, 2004 12:11 PM
