looking for F22b info
Old Aug 20, 2006 | 10:46 PM
MadCityLude
Guest
Posts: n/a
Default looking for F22b info
I got my hands on an F22b sohc vtec from an accord with 75k on it for real cheap the other day, now it needs a throttle body, injectors and rail, ecu, harness, and a tranny so I can bolt it in my new 92 Prelude SI 4ws I purchased. Can I use F22a parts? What ecu do I need? Anyone got specifics on this motor? HP? TQ? bore? Compression? Stroke? This is Iron sleeved like the F22a block correct? Thanks for the help!
Can I bolt an H22a intake manifold and throttle body up to it?
Modified by MadCityLude at 3:52 AM 8/21/2006
Old Aug 21, 2006 | 02:04 AM
InvaderTrax's Avatar
Best way to get the info you need, post this in the Accord section
Old Aug 21, 2006 | 05:55 AM
prelittlelude's Avatar
Default Re: looking for F22b info (MadCityLude)
iron sleeve, 85 bore 95 stroke 8.8:1 CR and yes your f22a parts will all swap over
edit: the only thing you can bolt to a f22 head that is close to the h22 intake mani would be the h23 intake mani. physically the h23 mani bolts up but some port matching would need to be done since the h23 intake runners are opend up much larger than the f22. often f22 guys bolt on h23 intake mani and port thier f22 head in search of more power.
Old Aug 21, 2006 | 07:05 AM
MadCityLude
Guest
Posts: n/a
Default Re: looking for F22b info (prelittlelude)
thanks for the help prelittlelude.
sounds like a good boost motor? or maybe ill do the H22 head first.
Old Aug 21, 2006 | 07:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help prelittlelude.
sounds like a good boost motor? or maybe ill do the H22 head first.</TD></TR></TABLE>
ive been bboosting on my f22b2 for a long time now , i have 9:1 cr because i decked the block with 35 thousanths of an inch because with the bigger combution chambers of the h22 head and an already super low 8.8:1 cr i wanted to up it
my motor has been holding up just fine
Old Aug 21, 2006 | 07:58 AM
MadCityLude
Guest
Posts: n/a
what turbo setup are you running? how much do you boost daily? is it daily driven? what sort of numbers have you put down? thanks again
Old Aug 21, 2006 | 08:09 AM
its a peiced together setup, im runing between 9-10 psi, i never dynod, i hope to get to the track before the end of aug. and i will weigh my car on my way to the track
its not my daily driver but i do practically drive it every day
Old Aug 21, 2006 | 08:26 AM
MadCityLude
Guest
Posts: n/a
200whp++ close to it?
would 250whp ++ be optimistic for a stock F22b-H22vtec hybrid boosted?
Modified by MadCityLude at 12:51 PM 8/21/2006
Old Aug 21, 2006 | 09:41 AM
Chuckles99SH's Avatar
I've searched out in the accord forum and seen a few set ups that yeild 300hp or so on stock internals of the F-series. I wouldnt be suprised if his setup was around 250-275 with those mods.
Old Aug 21, 2006 | 03:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">200whp++ close to it?
Modified by MadCityLude at 12:51 PM 8/21/2006</TD></TR></TABLE>
well ill give you guestmate in a week or two. I will use one of those online calculators that when given your vehicle weight and all the quater mile slip information it can give a fairly accurate whp number.
Old Aug 21, 2006 | 03:48 PM
MadCityLude
Guest
Posts: n/a
yea, I am just curious. In case I ever do boost
Old Aug 21, 2006 | 04:07 PM
ECX's Avatar
ECX
* B A N N E D *
eh
I dont like these motors, my moms auto EX Accord has it and I dont like it... so weak
Old Aug 21, 2006 | 04:14 PM
MadCityLude
Guest
Posts: n/a
Default Re: (ECX)
You gotta figure in the Auto Accord tranny into the factor there though. I am not expecting it to keep up with my JDM H22 Lude or nothing. Till I boost
Old Aug 21, 2006 | 04:17 PM
Default Re: (ECX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECX &raquo;</TD></TR><TR><TD CLASS="quote">eh
I dont like these motors, my moms auto EX Accord has it and I dont like it... so weak</TD></TR></TABLE>
Think about what you just said. Your mom's auto Accord feels weak
Old Aug 21, 2006 | 04:55 PM
ECX's Avatar
ECX
* B A N N E D *
Default Re: (InvaderTrax)
Does a 5speed tranny make that big of a difference?
Old Aug 21, 2006 | 04:58 PM
v4lu3s's Avatar
RTFM
the h23 manifold will not bolt up to the f22b# engines. only f22a# engines.
Old Aug 21, 2006 | 05:10 PM
MadCityLude
Guest
Posts: n/a
Default Re: (ECX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECX &raquo;</TD></TR><TR><TD CLASS="quote">Does a 5speed tranny make that big of a difference?
Any car is alot faster in manual. Less power loss, and much better gearing.
Old Aug 21, 2006 | 05:28 PM
sleepyH22's Avatar
i will say i will never own an auto honda....5spd is much more reliable...imo
slo2k
Jun 9, 2011 09:02 PM
blurry454
Jun 21, 2009 01:45 AM
breakyadown_89
May 2, 2009 11:15 AM
BigWillieStyles
Mar 16, 2006 12:23 PM
greensleeper
Sep 30, 2002 07:32 AM
