Suspension & Brakes Theory, alignment, spring rates....
another spring rate question :P
Old Aug 20, 2006 | 10:14 PM
davidluko's Avatar
Default another spring rate question :P
According to Honda-Tech:
H&R Race springs: "For an Integra they are 460f/350r (lbs/in)"
Eibach Pro Kit: "Eibach Pro Kit (for DC2) Front 331lb/in Rear 126-194lb/in *Progressive rate"
So I'm wondering if those are accurate. My brother has Koni Yellows with H&R Race springs on his Integra, and the springs seem too soft. I'm about to get Tokico Illuminas with the Eibach Pro Kit springs (used and cheap from my brother-in-law) so I'm wondering if my ride is going to be super soft. I drive a DB8.
Old Aug 20, 2006 | 10:44 PM
Tyson's Avatar
Default Re: another spring rate question :P (Hatch_R)
i could be wrong... but my source says 450/170-257 for 90-93 integra eibach prokits.
(which is considerable compared to the crx, but considering its weight...)
no i dont think its too soft.
Old Aug 21, 2006 | 11:12 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">According to Honda-Tech:
So I'm wondering if those are accurate. My brother has Koni Yellows with H&R Race springs on his Integra, and the springs seem too soft. I'm about to get Tokico Illuminas with the Eibach Pro Kit springs (used and cheap from my brother-in-law) so I'm wondering if my ride is going to be super soft. I drive a DB8.</TD></TR></TABLE>
Running 400/400 springs in my DC2, and its not too soft for the street, closer to the too stiff end of the spectrum. Its still completely streetable, but there's a few sections of the freeway that do bump me out of the seat. So, my guess would be if you think the H&R are too soft, then those must not be accurate rates for them.
Now, for autox and/or HPDE use, it is definately too soft. The car takes longer than I'd like to take a set, and there is definately more body roll than desireable.
331/194 won't be too soft, especially when you consider that the stock rates are only 220/110. You'll still have body roll, but nothing shy of a massive swaybar and race rates will get rid of it completely.
Old Aug 21, 2006 | 06:34 PM
davidluko's Avatar
Well I know the Eibachs are a lot stiffer than stock but I like a pretty stiff ride so I was thinking they might be a bit too soft when I turn up the stiffness on the shocks. I guess I'll find out soon cause I finally got the shocks and springs today which I have been trying to get all summer from my brother-in-law.
Seye
Suspension & Brakes
Oct 2, 2006 07:31 AM
No-Gi
May 24, 2004 04:19 PM
deviant1
May 3, 2004 08:09 PM
SCsol
Jan 18, 2002 06:22 PM
