gsr into del sol vtec?
Old Aug 20, 2006 | 06:43 PM
yacousmc's Avatar
Default gsr into del sol vtec?
I have searched and i cant really find what im looking for.
I am putting a jdm obd1 gsr into my 95 del sol vtec tomorrow. i just wanted to know if there is anything i should be watching out for or if it is a direct swap. i know the mechanical part is easy and bolts in. i just wanted to know if there is any wiring problems i should be looking out for? i also want to know if the exhaust manifold bolts up to my down piping
Old Aug 21, 2006 | 07:44 AM
yacousmc's Avatar
Default Re: gsr into del sol vtec? (yacousmc)
bump
Old Aug 21, 2006 | 09:51 AM
instrument's Avatar
hey, i've done this the other way around (pulled gsr out of del sol)
do you have the correct shift linkage? I'm assuming by vtec you mean dohc vtec, if so you're good.
also don't forget to unscrew the gas cap before you remove the fuel line to relieve pressure..
and you can't be too modest with the pb blaster..
that's it man, i've only done three swaps, the last two were on my own, it's a really simple swap as long as you have all the tools at hand.... and don't forget about the 8mm punch.
good luck
Old Aug 21, 2006 | 10:56 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: (instrument)
You will need the shift linkage from a B16 del sol and wire the butterflies for the gsr If its not the b16 del sol you will need axles, half shaft and rear bracket
bo98teg
Jul 7, 2010 03:20 PM
allmotorEG-SI
22
Dec 31, 2008 09:17 AM
healloitslasky
May 12, 2007 09:30 AM
leroyb
12
Nov 27, 2006 07:44 AM
