which tranny do i have
Old Aug 20, 2006 | 06:36 PM
Craigp23usa's Avatar
Default which tranny do i have
i believe i have the y1 b16 tranny. i know i have lsd but it appears that the case has ben opened and dont know if it is the stiock lsd.
how do you tell the difference between trannies?
how do you tell what kind of lsd it is?
thanks
Old Aug 20, 2006 | 08:49 PM
unknown0001's Avatar
Default Re: which tranny do i have (Craigp23usa)
What does it say on the tranny itself? any stickers with barcodes?
it's hard to tell what LSD you have unless you open up the transmission, but then it's hard to tell unless the factory had it stamped when it was produced
Old Aug 20, 2006 | 10:00 PM
there are no stickers. i bout it from h motors online and i believe it is the y1. i have the tranny apart and i think that it is a stock lsd but i dont see a stamp.
it is a clutch type.
i do know it is a clutch type lsd
Old Aug 21, 2006 | 04:10 AM
F20Cteg's Avatar
Default Re: (Craigp23usa)
LSDs are easily identifiable because they don't have a pinion to connect any spider gears.
Look through the hole were the axle goes. If it doesn't have a bar and you can see all the way way through, then it is an LSD differential.
Stock LSDs are hypoid type. They don't use clutches. They use gears.
Old Aug 21, 2006 | 05:24 AM
i know it has lsd (hollow hole) ill take a close lok and try to find out wich one i have.
also the differential bearing is a sealed bearing and maked a bit more noise thn the others. is this dormal due the the larger size?
should it be completely quite?
also the tranny is stamped ysk? there are also some numbers at the verto of the case.
Modified by Craigp23usa at 9:40 AM 8/21/2006
Modified by Craigp23usa at 9:42 AM 8/21/2006
albertaEK
33
Nov 10, 2007 11:51 AM
the.hamburglar
Sep 13, 2005 02:44 PM
CRX A4
Apr 5, 2003 04:04 AM
Nextelbuddy
Mar 31, 2003 07:40 PM
charjacq
14
Dec 10, 2002 07:57 PM
