************wiring diagram for a 93 gsr dash into a 90 crx*************
okayyyy so i fit a 93 gsr dash into my 90 crx but i cant find any wiring diagrams please help people i need to get that **** hooked up soooo any info people please help
JdM_RaCeR
JdM_RaCeR
This is for the 90-93 integra LS, so i would double check it before going through with it.
A1 Yellow/Red Seat Belt Reminder Light
A2 Green/Red Parking Brake Switch Light
A3 Green/Black Hatch Open Indicator Light
A4 Green/Red Low Fuel Indicator Light
A5 Yellow/White Fuel Gauge
A6 Yellow/Red ECM, Trans Control, Moduel TCM, Cruise Unit, VSS
A7 Red Gauge Lights, Dash Light Dim
A8 Empty
A9 Red/Black Gauge Lights
A10 Green/Yellow Right Turn Signal Indicator
B1 Green/Blue Left Turn Signal Indicator
B2 Red/Blue High Beam Indicator
B3 Blue/Red ABS Indicator Light
B4 Blue Tachometer
B5 Green/Red Door Open Indicator Light
B6 Yellow/Green Engine Coolant Temp Gauge
B7 Black Ground
B8 Yellow Ignition Power
B9 Green/Orange Malfunction Indicator (Ck Eng.) Light
B10 Black/Yellow Charging Sysem
B11 White/Blue Charging System (Battery) Light
B12 Yellow/Red Low Engine Oil Pressure Light
hope this helps
A8 Empty
B4 Blue Tachometer
B7 Black Ground
hope this helps
afterdark
10
Feb 25, 2012 09:31 AM
