5 lug conversion on EG
Old Aug 20, 2006 | 05:29 PM
JDM_SOHC's Avatar
Default 5 lug conversion on EG
Im about to do this swap an have been reading up on a lot of DIY's an just readin different stories about swaps that have been done... How does this sound to maybe 5 lug owners or people who have done swaps.... Does this swap look complete..?? Thanks... http://cgi.ebay.com/ebaymotors...QrdZ1
Old Aug 20, 2006 | 06:59 PM
BlueIntegraBoy's Avatar
Default Re: 5 lug conversion on EG (JDM_SOHC)
Looks complete to me. You'll need a larger master cylinder and 4040 prop valve.
Old Aug 20, 2006 | 07:06 PM
highroller54's Avatar
Default Re: 5 lug conversion on EG (BlueIntegraBoy)
you will need a b series swap, they are 36mm's
Old Aug 20, 2006 | 07:11 PM
cambopheonix56's Avatar
Default Re: 5 lug conversion on EG (highroller54)
jdm_planet( 0 )
SHIPING COST ANYWHERE IN UNITED STATES AND CANADA 200$
No thanks.
Old Aug 20, 2006 | 07:18 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 5 lug conversion on EG (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 &raquo;</TD></TR><TR><TD CLASS="quote">you will need a b series swap, they are 36mm's</TD></TR></TABLE>
You will need a B-Series swap yes, but you will also need custom axles, since the hubs are 36mm, and not 32.
Old Aug 20, 2006 | 09:00 PM
Default Re: 5 lug conversion on EG (JDM_Ej)
if you had a b series you would just need the jdm type r axles.
Old Aug 23, 2006 | 02:22 PM
JDM_SOHC's Avatar
so u cant have a D series engine an 5 lug wheels whatsoever???
Old Aug 23, 2006 | 02:28 PM
racer22's Avatar
I wouldnt buy from his, for the simple fact he has a ZERO!!!! but it looks complete.
Old Aug 23, 2006 | 04:55 PM
jdmsiR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote">so u cant have a D series engine an 5 lug wheels whatsoever???</TD></TR></TABLE>
you can...
but for d-series, the axles use a 32mm splined end. you're gonna have to find a 5-lug with a 32mm hub (which is more abundant than the 36mm).
Old Aug 27, 2006 | 07:58 PM
JDM_SOHC's Avatar
Default Re: 5 lug conversion on EG (jdmsiR20)
well what if its the US Spec ITR..??? arent the spindlethreads gonna be the same..?? i thought only the JDM ITR or CTR were 36, and everything else was 32..???????
Old Aug 27, 2006 | 10:33 PM
jdmsiR20's Avatar
yup, all US spec ITR's are 32mm
Old Aug 29, 2006 | 03:09 PM
JDM_SOHC's Avatar
but how can u tell the difference in JDM an USDM ITR..?? wheel assembly wise anyways..??
blaze2010
Dec 9, 2008 01:25 PM
hondatuner020
12
Apr 11, 2007 07:11 AM
ykenny1
Mar 19, 2006 03:43 AM
The Alchemist...
May 6, 2005 08:03 AM
BIGthings
May 22, 2004 03:53 PM
