just did wire tuck *pics* and how to unpin headlight sockets
Old Aug 20, 2006 | 03:57 PM
89hatcher's Avatar
Default just did wire tuck *pics* and how to unpin headlight sockets
here's the before piture of how it looked like in the engine bay with fuse box and all the wires
and heres the piture with the engine harness all tucked
oh and heres the tech
first depin from an extra harness you have you will need (2) pins
this is what you need
then look at the headlight socket
the insert the 2 pins in the 2 holes on the "center" of the socket *don't put the pins in the headlight pins*
then insert a small screw driver on the side of sockt and pry open and it should look like this after you pry it open
then remove the white cap that you just pryed open then tit looks like this
then insert a small screwdriver on the headlight pin and then move the screwdriver with the pin so that you are making the pin torward the outside of the socket
then you push down with the screwdriver and the pin should come out like so
Old Aug 20, 2006 | 06:02 PM
civhatch90's Avatar
looking better, nice work
b1699dx
Sep 24, 2012 10:03 AM
Frost7177
Oct 18, 2009 08:30 PM
CORE132
10
Jun 4, 2009 09:32 PM
tanabedc2
Aug 14, 2006 06:22 PM
