B16 bogging?
i have a obd0 b16 and it boggs like crazy. Once it hits vetc its fine but up until it has nothing. also the car idles really high, i turned it down as far as i could at the throttle body. the only way i can make it go down it by messing with my timing, but if i do that its boggs 10 times worse any advice?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatchBox Racer »</TD></TR><TR><TD CLASS="quote">I just put a new tps in, how do i know when it is adjusted right
Thats probably you're problem then,cause the tps sure does cause some bogging..Check this http://www.integra.orcon.net.nz/tps
Check the adjustment on it. Its probably rivited. Remove the thottlebody remove the rivits using maybe a screwdriver to break the rivits and install 8mm (is what i used) bolts. So that you can loosen them and adjust the tps sensor. I would first check the adjustment on it and get a known good used one if you can if it is bad. I just go by sound when i adjusted mine. Let the engine idle and adjust it. You can use a dvom to make sure its properly adjusted. I am pretty sure its a 5 volt reference.
gatesrex91
Mar 28, 2002 09:53 PM
