Suspension & Brakes Theory, alignment, spring rates....
Need Help on Suspension BAD....
Old Aug 20, 2006 | 03:13 PM
B18Sleeper's Avatar
Default Need Help on Suspension BAD....
Ok I am working on a pretty powerful motor....hope to get numbers around 400, but my problem is i dont know what all for suspension and body bracing i should do with.....this car is going ot be a drag car 98% of the time and the other 2% will be when i take it out on the road to a show or out somewhere to show someone. so what is everyones suggestions....sorry i have searched and read, but i am still lost. suspension is not my field all i got from research is this....
Koni Yellow Shocks
Ground Control Coilovers
So what else shoudl i go with...thanks alot
Old Aug 20, 2006 | 03:34 PM
chrisw85's Avatar
If its not going to be street driven and will be a track only drag car, then cage it. Best way to stiffen up the chassis and provide protection.
Old Aug 20, 2006 | 04:03 PM
B18Sleeper's Avatar
Default Re: (chrisw85)
yea i thought about that but i want it to stay clean and look like a sleeper....that is the only problem i want when ppl open the door to see the dash, carpet, and backseat, but i may still cage it....more work then i want but yes it will provide protection...any other suggestions?
Old Aug 20, 2006 | 04:04 PM
B18Sleeper's Avatar
Default Re: (B18Sleeper)
oh yea nad it iwll be on the road some but its just not a dd....its more or less out on a weekend for once a month or twice a month only in good weather...
Old Aug 21, 2006 | 05:26 AM
B18Sleeper's Avatar
bump
Old Aug 21, 2006 | 08:33 AM
PIC Performance's Avatar
Default Re: Need Help on Suspension BAD.... (B18Sleeper)
Most tracks seem to require a cage if the car runs less than 12's, so if you plan on that, then you'll need to have a cage built anyways. unless you don't plan on doing your drag racing at an actual track......
Traction bars and some stiffer motor mount inserts will help reduce wheelhop at the front. Dampers with some more rebound in the front, and stiffer springs + more compression in the rear will help with squat.
Old Aug 21, 2006 | 02:50 PM
B18Sleeper's Avatar
Default Re: Need Help on Suspension BAD.... (PIC Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">Traction bars and some stiffer motor mount inserts will help reduce wheelhop at the front. Dampers with some more rebound in the front, and stiffer springs + more compression in the rear will help with squat. </TD></TR></TABLE>
Could u point me in the direction of brands and specifics? like the lb of springs and all that...
Old Aug 22, 2006 | 04:32 AM
B18Sleeper's Avatar
bump
Old Aug 22, 2006 | 08:22 AM
A good thread on traction bars:
https://honda-tech.com/zerothread?id=1183730
Energy suspension makes polyurethane motor mount inserts that many people seem to use with good results.
I can tell you what to look for in the shocks and springs, but you're asking the wrong person if you want brand names. Generally, the higher the spring rate in the rear, the less the rear end will squat. It is not unheard of to run 1000+lbs/in springs in the rear for a drag car. But that will be undriveable - figure your car has something like 150lbs/in springs in the rear stock or something (not sure of the exact #). The shocks should simply be valved with greater rebound in the front and compression in the rear ("greater" meaning more; more rebound is more resistant to the extension of the shock, more compression is more resistant to compression of the shock).
Old Aug 22, 2006 | 11:53 AM
B18Sleeper's Avatar
thanks for your help
StreetRacinThug
Nov 30, 2009 10:58 PM
B16aCRXSi
Jan 30, 2009 08:38 AM
svmnredracr
Jul 21, 2004 11:57 PM
G2Integrity
Jul 3, 2002 04:51 PM
ZXVIIR
Apr 21, 2002 02:39 PM
