99 civic si wont turn on need help please
Old Aug 20, 2006 | 12:47 PM
3k9civic's Avatar
Default 99 civic si wont turn on need help please
a week ago i start up the civic, it turn on and run good, a week later i tried to turn on the car, first it crank then the batery died. so i just left the car there, the next day i tried jump the battery to start the car again, nothing turn on. the car wont turn over, nothing happen. light ect. nothing, not even the emergeny signal wont even turn on. any suggestion?
Old Aug 20, 2006 | 12:49 PM
philosofy1's Avatar
Default Re: 99 civic si wont turn on need help please (3k9civic)
sounds like your alternator died and took the battery with it.
Old Aug 20, 2006 | 01:35 PM
3k9civic's Avatar
Default Re: 99 civic si wont turn on need help please (philosofy1)
i dont think its the altinator. because nothing in the car turn on. car wont crank, cant hear fuel pump, nothing. i turn the key to start potion and tried to crank stil nothing happen
Old Aug 20, 2006 | 02:11 PM
Michler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your alternator died and took the battery with it.</TD></TR></TABLE>
Old Aug 20, 2006 | 03:11 PM
TorquelessB16's Avatar
Trickle charge it AND jump it and see what happens. But I would agree with the alternator being shot.
Old Aug 20, 2006 | 03:19 PM
superacecardriver's Avatar
Default Re: 99 civic si wont turn on need help please (TorquelessB16)
check the main fuse.
Old Aug 20, 2006 | 03:58 PM
lunaticraver's Avatar
Try push starting the car see if that will work. Is it stick?
Old Aug 20, 2006 | 04:27 PM
lonefuzzy79's Avatar
Default Re: (lunaticraver)
You have no battery power in your car. The battery is dead. End of story. Take the battery out and have it tested to see if it is shot. If not, charge it.
If it runs down again you have either:
A) A dead alternator
B) A leak in your electrical system (ie. A poorly installed electrical component like a stereo or alarm system which is draining the battery after you shut the car off)
C) You are a complete dumbshit noob who leaves his lights on and then wonders why his car won't start in the morning in which case you shoud:
A) Find a railroad crossing and push you and your car into the tracks and wait for a train.
B) Take a stroll on the freeway.
C) Push you and your car into the ocean off a short pier
hope this helps.
Old Aug 21, 2006 | 08:07 AM
jz98ctr's Avatar
dude if nothing is working electrically in ur vehicle check the main fuse. sometimes after jump-starting a car you overload the main fuse and it pops...check that first!
Old Aug 22, 2006 | 02:52 PM
3k9civic's Avatar
Default Re: (jz98ctr)
well i did chech the fuse and everything seem to be good, no burn fuse. well today i try out the accessories light inside the car and it work, the emergency light, fuel is pump ect. work perfect, but then when i tried to jump start the car, everything went out again.
Old Aug 22, 2006 | 02:56 PM
philosofy1's Avatar
Default Re: (3k9civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3k9civic &raquo;</TD></TR><TR><TD CLASS="quote">i dont think its the altinator. because nothing in the car turn on. car wont crank, cant hear fuel pump, nothing. i turn the key to start potion and tried to crank stil nothing happen</TD></TR></TABLE>
i guess you never had a alternator kill your car before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3k9civic &raquo;</TD></TR><TR><TD CLASS="quote">a week ago i start up the civic, it turn on and run good, a week later i tried to turn on the car, first it crank then the batery died. so i just left the car there, the next day i tried jump the battery to start the car again, nothing turn on. the car wont turn over, nothing happen. light ect. nothing, not even the emergeny signal wont even turn on. any suggestion?</TD></TR></TABLE>
yes you can jump it, it might start, but a bad , very bad alternator will shut everything down. have it check as well as the battery and double check your ground wires.
amej8
Honda Civic (2006 - 2015)
25
Feb 10, 2011 06:31 PM
Stunna MIKE
Jan 19, 2011 07:08 PM
Legendaryyaj
Mar 8, 2007 01:41 PM
Muckman
Oct 4, 2006 08:20 AM
brad86
May 30, 2004 02:37 PM
