No crank, no start
Old Aug 20, 2006 | 12:10 PM
NathanielH's Avatar
Default No crank, no start
I just got done swapping my b16a (sir2) into my eg hatch. with the key on, engine off the cel is solid, not flashing. when i go to crank it to start it, i hear a popping noise and all guages/lights shut off, and it wont crank, or make any sound. i let it wait for a few mineuts, and then i put it back in the on position and the guages are lit p again, and the CEL is still solid, i go to start it and it does the same thing. dose anyone have any idea?
Old Aug 20, 2006 | 01:01 PM
vtec_inside's Avatar
Default Re: No crank, no start (NathanielH)
it look's like a wrong batterie connection to me !
Old Aug 20, 2006 | 02:58 PM
turbociviccoupe's Avatar
check all your grounds...including the one on the valve cover....tranny...and thermostat housing and check your battery
Old Aug 20, 2006 | 03:04 PM
amy's Avatar
amy
Default Re: No crank, no start (teg xsi)
i'd replace your battery with one that you know is from a good running/starting car... chances are that's what it is
Old Aug 20, 2006 | 04:19 PM
NathanielH's Avatar
Default Re: No crank, no start (amy)
ok, i fixed the ground wire from the front of the valve cover, it is now cranking, but not starting. there is no spark coming from the plug wires/cap. i checked the voltage at the 2 pin connector with the Key on enigne off, and there is a full 12.6 volts... is the coil shot? dose anyone have a link to testing the coil inside the distributor? Thanks alot for the help buy the way guys. and girls
Old Aug 20, 2006 | 04:41 PM
replace your ignitor with the one you had inside your old engine distributor then try it again !
Old Aug 21, 2006 | 05:12 AM
NathanielH's Avatar
well, i didnt get it running yesterday. so i had to quit and start on it next weekend (i live in a different state than where the car is). Dose anyone know wich pins i should check for power in the 10 pin connector that is also coming off the distributor?
DIZSTRICTxB3A5T
Mar 11, 2011 12:41 PM
civic_si1320
11
Sep 2, 2010 05:59 PM
Jameson
Jan 28, 2008 02:00 PM
4b1z
Jan 29, 2005 05:21 PM
sounique
Apr 16, 2003 04:23 PM
