Firewall in a 1997 GS-R
Old Apr 25, 2002 | 09:40 PM
fluke702's Avatar
Default Firewall in a 1997 GS-R
I have 2 questions:
1) I'm trying to install my amp and want to know, who knows of a good hole in the firewall on the passenger side to slip my power wire? I'm gonna run the wires from the back on the passenger side since the battery is on that side. This is specifically for a 1997 integra 2 door gs-r. Does anyone know any firewall hole?
2) I'm also going to hook up my 1/2 farad capacitor and I forgot the instructions on how to charge it up. Does anyone know how again?
Thanks!
Old Apr 26, 2002 | 05:00 PM
94civicx's Avatar
New User
Default Re: Firewall in a 1997 GS-R (fluke702)
Run the wire through the rubber hole next to the battery. If you look at the battery, to the bottom right there is a rubber plug that you can remove to put the wire through the firewall. as far as question #2, don't know
[Modified by 94civicx, 2:01 AM 4/27/2002]
Old Apr 27, 2002 | 06:31 AM
95CoupinIt's Avatar
u need the supplied resistor to charge your cap. if u lost it, call the manufacturer of the cap (RF, Lightning, ETC) to get the correct supplied resistor, or just go down to your local shop and ask them to charge it for you. at any rate, just use your car battery with the resistor to charge the cap up,.....make sure u get teh polarity right otherwise u'll ruin the cap
Old Apr 28, 2002 | 02:35 PM
Diabolik's Avatar
Default Re: Firewall in a 1997 GS-R (95CoupinIt)
You don't need the resistor. All you need is a resistance. Just use a test light from your power wire to the cap. I charge mine like that all the time.
-Diabolik
Freshdot
Nov 15, 2012 09:07 PM
Prophet1990
Feb 18, 2012 11:21 AM
f22a1 ftw
Aug 22, 2010 12:43 PM
Mashi2Choco
Apr 21, 2008 11:29 AM
rdeezy78
Audio / Security / Video
10
Aug 27, 2007 03:16 PM
