OBD0 code. HELP
the other day i was going to work and my car just crapped out, i tihnkits the fuel pump but the computer was giving me consistant blinking light and i dont know what that means
any thoughts?
any thoughts?
this page has all the codes:
https://honda-tech.com/zerothread?id=1171263
just count the blinks and check that page. pull the carpet back put key to on position and you can see the light on the ECU.
turn the key on and hear for the fuel pump priming in the rear inside the tank. Just sit in the driver seat and turn the key on and listen for the fuel pump to come on. Check the main relay first. Under the driverside dash on the left side kick panel. Black box. I think its like a 16p conector. Tap the relay of hit the realy and try to start the car. Before condeming the fuel pump check the relay first. More common in these cars, the contacts inside the relay break away from corrosion or other means.
B18 CYA
15
Sep 16, 2006 12:04 PM
