HELP....Wiring Question for Type-R B18C into a 98 Coupe EX
Old Aug 20, 2006 | 07:56 AM
jz98ctr's Avatar
Default HELP....Wiring Question for Type-R B18C into a 98 Coupe EX
I'm tired of getting the runaround from local shops...i got a 98 EX coupe with what I think is either a 96 or 97 JDM B18C Type-R motor with a P73 ECU
I need to know what engine harness i need for this cuz i got all sorts of extra plugs and i don't even know if it's OBDI or OBDII or some combination thereof
OBDI, OBD1.5A B Q M X L VZ i got no clue. please help!
Old Aug 21, 2006 | 08:12 AM
jz98ctr's Avatar
nebody
i thought this place was for help not to be ignored
Old Aug 21, 2006 | 08:20 AM
BigRonDawg's Avatar
Default Re: (jz98ctr)
i used a 96-98 civic ex harness on my swap... but you need to find out what obd your engine is... a good place to check is your ecu
also, your head has a stamp in it telling you what year it was made... it's by the header... that will give you an idea as well.
Old Aug 21, 2006 | 08:39 AM
Slopoke's Avatar
Default Re: HELP....Wiring Question for Type-R B18C into a 98 Coupe EX (jz98ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz98ctr &raquo;</TD></TR><TR><TD CLASS="quote">I'm tired of getting the runaround from local shops...i got a 98 EX coupe with what I think is either a 96 or 97 JDM B18C Type-R motor with a P73 ECU
OBDI, OBD1.5A B Q M X L VZ i got no clue. please help! </TD></TR></TABLE>
Your car is obd2A
The JDM itr motor is also obd2A
You have to reuse your stock harness and fit it to the ITR motor.
Old Aug 21, 2006 | 08:43 PM
jz98ctr's Avatar
it's a P73 ECU
I also noticed that my reverse lights no longer work because i think the factory ECU handles that duty while the JDM integra had an outboard relay to control the lights
Old Aug 22, 2006 | 09:04 AM
Slopoke's Avatar
Im pretty sure your ecu has nothing to do with your reverse lights. lol
Did you plug them in(the connector on the tranny)?
Old Aug 22, 2006 | 05:38 PM
jz98ctr's Avatar
i'm pretty sure the stock ECU had an internal relay that saw the reverse continuity switch from the tranny to the ECU. I used a digital multimeter to test for continuity and the switch which sends the signal is good. the 2 wires get continuity when put into reverse.
Old Aug 22, 2006 | 05:40 PM
jz98ctr's Avatar
i'm not real concerned with the reverse lights...worse comes to worse i can wire up a relay to do the job. i'm more worried bout which engine harness to use.
Old Aug 23, 2006 | 08:48 AM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz98ctr &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty sure the stock ECU had an internal relay that saw the reverse continuity switch from the tranny to the ECU. I used a digital multimeter to test for continuity and the switch which sends the signal is good. the 2 wires get continuity when put into reverse. </TD></TR></TABLE>
I looked at the wiring diagrams on the '98 civic and it shows nothing in the back-up light curcuit going to the ecu. There is just power to the back-up switch(from fuse #19). When you put the car into reverse, it completes the ciruit and sends power to the reverse lights. Thats is. No ecu or relays involved.
Works the exact same way in an integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz98ctr &raquo;</TD></TR><TR><TD CLASS="quote">i'm not real concerned with the reverse lights...worse comes to worse i can wire up a relay to do the job. i'm more worried bout which engine harness to use.</TD></TR></TABLE>
You have to reuse your '98 civic harness.
Old Aug 24, 2006 | 08:20 AM
jz98ctr's Avatar
Thanx man
Old Aug 24, 2006 | 08:45 AM
jz98ctr's Avatar
oh yea i forgot..when i had my swap dun...the only harness i had was from an automatic maybe that's why there are the reverse switch wires at the ECU as well as the reverse wire itslef
nutty562
Apr 12, 2008 11:02 PM
hayabusa750
Feb 15, 2007 03:48 PM
ricky05
Mar 13, 2006 02:30 PM
racers4life77
Mar 9, 2004 06:16 PM
pennies_hatchie
Sep 10, 2003 04:32 PM
