Alarm Install on integra 1994
Old Aug 20, 2006 | 07:52 AM
lsvtek's Avatar
Default Alarm Install on integra 1994
Hey, alright I have a black widow alarm system that I am trying to install in my integra, and I was wondering if I slice the black/yellow wire or the black/white wire? Also I wired up the door locks and it seemed to only unlock and not lock, but I sliced into the black/white wire, I need help to install this alarm any help will be great thanks
Old Aug 20, 2006 | 08:00 AM
94_DC4's Avatar
Default Re: Alarm Install on integra 1994 (4drlsintegra)
Does your car have cruise control? If it does the lock/unlock wires are behind the cruise control module on the drivers side kick panel. The wires are black/red and black/white. The black yellow wire is the ignition wire and the black/white the starter wire. You cut the black/white to do the starter kill.Or you can do an ignition kill. It's up to you.
Old Aug 20, 2006 | 08:07 AM
lsvtek's Avatar
Default Re: Alarm Install on integra 1994 (SiRGDC)
DAMNIT! I wish I went with the black/white, Not I have to cut wires put together, Also YES, I wired up the unlock/lock wires right also, but i dont know what happened
Old Aug 20, 2006 | 04:56 PM
lsvtek's Avatar
bump
Old Aug 21, 2006 | 05:00 PM
suspendedHatch's Avatar
What are you bumping for?!
If you already cut the black/yellow, just use that. Only bad thing about it is that if you keep cranking on your motor when the alarm is going off, you'll be dumping fuel.
Old Aug 21, 2006 | 10:26 PM
lsvtek's Avatar
Default Re: Alarm Install on integra 1994 (suspendedHatch)
lol, i mean I have more problems, I cut the black/white wire now, but I still have a problem with the lock/unlock, it seems to ONLY Unlock, even if I arm the car, and I still have my old factory alarm but took the brain out, mayb the wires have something to do with this?
Old Aug 22, 2006 | 12:49 AM
lsvtek's Avatar
alright, I got the unlock/lock wires all figured out. but now, my car starts even if the alarm has been armed and if it goes off I can still start the car, any help would be great
Old Aug 22, 2006 | 02:10 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
relay is not installed correctly. How do you have it wired up.
Old Aug 22, 2006 | 09:33 AM
lsvtek's Avatar
Default Re: Alarm Install on integra 1994 (wrx-killer-Sti eater)
I didnt use a relay for lock/unlock
Old Aug 23, 2006 | 05:57 AM
94_DC4's Avatar
How did you wire the starter kill relay?
Old Aug 23, 2006 | 08:56 PM
lsvtek's Avatar
everything is fixed, it is up and working tanks for all ur help
Asmar
Audio / Security / Video
Jul 8, 2013 10:20 PM
tehjrow
Oct 2, 2011 09:47 AM
King970
Aug 10, 2010 05:10 AM
arbys2k
Honda S2000
May 5, 2006 02:07 AM
Azxster
Mar 26, 2006 09:20 AM
