Suspension & Brakes Theory, alignment, spring rates....
camber kit question
Old Aug 20, 2006 | 07:45 AM
crawlin's Avatar
Default camber kit question
my friend from work has front and rear camber kits for his 2000 si and he crashed his si and doesnt need them i have a 94 civic will the camber kit work for the front i know the rears will work but im unsure about the fronts i can pick the whole kit up cheap and would like to know
Old Aug 20, 2006 | 08:08 AM
chrisw85's Avatar
the front control arms are different on the 92-95 civics versus the 96-00. so while the rear will work, the front will not.
how bad is your camber? i'd just get a 0 toe aligment.
Old Aug 20, 2006 | 10:36 AM
crawlin's Avatar
Default Re: (chrisw85)
my car is pretty low wheels in the wells its more camber wear then tow
Old Aug 20, 2006 | 12:16 PM
chrisw85's Avatar
get an 0 toe aligment. if you have severe inner edge wear, thats toe. the negative camber accelerates this wear. so if you get it set to 0 you'll greatly reduce this accelerated wear on the inner edge no matter what your camber is at.
Old Aug 24, 2006 | 11:41 AM
NAmodified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">get an 0 toe aligment. if you have severe inner edge wear, thats toe. the negative camber accelerates this wear. so if you get it set to 0 you'll greatly reduce this accelerated wear on the inner edge no matter what your camber is at.</TD></TR></TABLE>
i think not. camber is more important than caster and toe. I will guarantee that your cars tires will eat up with offset camber and 0 toe. DONT listen to chris, do the investigation your self.
Old Aug 24, 2006 | 01:06 PM
Tyson's Avatar
Default Re: (NAmodified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified &raquo;</TD></TR><TR><TD CLASS="quote">
i think not. camber is more important than caster and toe. I will guarantee that your cars tires will eat up with offset camber and 0 toe. DONT listen to chris, do the investigation your self. </TD></TR></TABLE>
i think not to you.
fix toe, thats the main reason for eating tires on our hondas.
Noah Santana
11
Jan 18, 2017 06:09 AM
nindoo
Honda Civic (2006 - 2015)
Jul 30, 2007 08:23 AM
blk94gsr
Suspension & Brakes
Feb 15, 2006 08:49 AM
GreenMachineRex
Apr 18, 2005 03:29 PM
Accord2K1
Jul 11, 2003 06:00 PM
