swapping clusters/harness - which way? ::Searched::
Old Aug 20, 2006 | 07:38 AM
Syndacate's Avatar
Default swapping clusters/harness - which way? ::Searched::
Yeah, pretty straight forward...and yes I searched...
If putting a different cluster in your car (like I wanna put a 94-01 'teg cluster in my EJ1) and obviously the wires/plugs won't match. So I was wondering, which is "more efficient" way of doing it?
Way 1 - The way I was kinda thinking would be the best:
When getting the cluster from a junkyard and instead of unplugging it, just cut the harnesses before the plug so the wires are hanging (and you have the plugs in the cluster), taking it back, after looking at a wiring schamatic, just re-pin the old wires into the new plugs... Then it'll just plug in, and there's no soddering or cutting required, just repin the new plugs on the 'teg cluster with the wires unpinned from the old plugs...
Way 2 - The way everybody else seems to do it:
Just cut the wires and sodder them to their counterparts on the harness...or heat shrink, whatever.
I'm thinking that the first way's a lot more efficient, maybe more time consuming, but whatever.
Anybody have any advice? Good/bad results from either one?
Old Aug 20, 2006 | 07:12 PM
Syndacate's Avatar
Default Re: swapping clusters/harness - which way? ::Searched:: (Syndacate)
c'mon, somebody's g2 know.
Old Aug 20, 2006 | 07:52 PM
Jhonny Ricer's Avatar
https://honda-tech.com/zerothread?id=407737
That might help a little...
Old Aug 20, 2006 | 10:48 PM
Syndacate's Avatar
Default Re: swapping clusters/harness - which way? ::Searched:: (Jhonny Ricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=407737
That might help a little... </TD></TR></TABLE>
Eh, not really, thanks anyways. I was j/w which way is better, I'ma just re-pin it if I do it.
Old Aug 21, 2006 | 04:12 AM
BigRonDawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Eh, not really, thanks anyways. I was j/w which way is better, I'ma just re-pin it if I do it.</TD></TR></TABLE>
Repin it... thats how i did it... it's not hard...
Old Aug 21, 2006 | 11:20 PM
Default Re: swapping clusters/harness - which way? ::Searched:: (BigRonDawg)
Well he does show how to repin so you can keep the stock clips
michael-crxsi
Mar 8, 2010 07:16 AM
BlueIntegraBoy
Mar 8, 2005 07:10 AM
wsiracerz
Oct 19, 2004 09:26 AM
wsiracerz
Oct 18, 2004 08:36 PM
