h22 eg 1/4 et.'s
i recently swapped a jdm h22a into my eg hatch, and took it to the track. It is basically stock, i have the jdm lsd tranny, a short ram intake, 8lb. flywheel and six puck clutch, also have no cat, and greddy catback.
R/T .101
60' 2.399
330 6.236
1/8 9.379
MPH 78.51
1000 12.095
1/4 14.396
MPH 98.12
I'm wondering if this is a decent time, what i should be running, any comments or suggestions please!!!!!!!!!!!!!!! ? ?
R/T .101
60' 2.399
330 6.236
1/8 9.379
MPH 78.51
1000 12.095
1/4 14.396
MPH 98.12
I bet that light *** flywheel is skrewing you. If the flywheel is too light than you lose to much tourque. You should be pulling at least 99-100 with an h22 in a hatch. My buddys pulled 99 with intake and exhaust in ex 4door!!
yea i'm not sure whether or not it did anything, because i put the flywheel on before the motor ever saw the car. all i know is that it revs faster than my b16 with a lightened flywheel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuickDxEk »</TD></TR><TR><TD CLASS="quote"> If the flywheel is too light than you lose to much tourque. </TD></TR></TABLE>
That is an absolutely false statement.
The time seems about right to me. Some sticky tires and seat time will do wonders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuickDxEk »</TD></TR><TR><TD CLASS="quote">I bet that light *** flywheel is skrewing you.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuickDxEk »</TD></TR><TR><TD CLASS="quote">Ok, Its a false statement?? You take a fairly stock moter in a car, run it, than put an 8lb flywheel on there and run it again!! I have seen this problem alot!!</TD></TR></TABLE>
What "problem"? Do you honestly think a different flywheel will have any effect on horsepower/torque output? Come on.
A lighter flywheel will only make the car accelerate faster (though it will make launching more tricky and quick shifting more essential).
Modified by tim_adams85 at 8:21 PM 8/20/2006
14's that dont sound right, you should be hittin low 13's or high 12's. a buddy of mines is hittin 12's wit i/h/e in his h22 swap in a eg, it must be you mane, not to sound rude.
i have heard there are two different h22a's, one being 200hp, and the other being 220hp? I believe my motor is 200hp
Also, has anyone with a h22 eg ever ran at the track without the balance shaft belt on? i was reading in the prelude threads and a couple people said you can free up some power by removing the balance shaft belt. just wondering if there is any truth to that?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicjaydm »</TD></TR><TR><TD CLASS="quote">i have heard there are two different h22a's, one being 200hp, and the other being 220hp? I believe my motor is 200hp
Also, has anyone with a h22 eg ever ran at the track without the balance shaft belt on? i was reading in the prelude threads and a couple people said you can free up some power by removing the balance shaft belt. just wondering if there is any truth to that?!</TD></TR></TABLE>
i have the balance shafts eliminated in mine
SilverDc2
35
Apr 13, 2003 10:03 AM
