anyone use an "F1 racing" brand clutch??
Old Aug 19, 2006 | 10:09 PM
hella_usdm's Avatar
Default anyone use an "F1 racing" brand clutch??
I was checking these out on ebay and they seem like a great deal with the fidanza light weight flywheel and it looks like a better material than the oem exedy's that are prone to breaking. And its a carbon kevlar disc that won't burn up as fast as an organic disc. Thoughts? I need a new clutch soon and don't have a ton of money to drop on it.
http://cgi.ebay.com/ebaymotors...40460
Old Aug 19, 2006 | 11:17 PM
InvaderTrax's Avatar
If you wanna go and try it, go head. It's your car. But I'll let you know I was one of the guinea pigs for the XTD clutch, and after a year, it's not holding up so well
Old Aug 20, 2006 | 01:13 AM
russlan44's Avatar
Default Re: (InvaderTrax)
this looks like oem replacment clutch but it says stage 2
Old Aug 20, 2006 | 05:50 AM
98vtec's Avatar
moderator emeritus
Default Re: anyone use an "F1 racing" brand clutch?? (hella_usdm)
ebay.
Old Aug 20, 2006 | 07:39 AM
sleepyH22's Avatar
Default Re: anyone use an "F1 racing" brand clutch?? (98vtec)
DO NOT buy that clutch kit...
somewhere on ebay they have the exedy kit and exedy flywheel....go for that...def dont wanna have a cheap ebay knock off clutch
Old Aug 20, 2006 | 11:23 AM
l2yanE's Avatar
Default Re: anyone use an "F1 racing" brand clutch?? (sleepyH22)
I installed that kit on my friends h22 hatch, hooks up great good pedal, got 10000 miles on it no probs
Old Aug 20, 2006 | 12:01 PM
Honda Sport's Avatar
I've had my f1 racing clutch for about 6 months with no probs. I've got the stage 1. probably put about 5k-10k on it so far with no problems. gonna swap out to a ACT 6 puck again(lasted me a good 4 years of weekend track and daily driving, the splines on the disc gave out, wore out smooth. ) or exedy twin disc sooner or later...
Old Aug 20, 2006 | 01:15 PM
chitownrida's Avatar
i've used my ebay clutch with no problems
clutchnet stage 2
make sure you machine the flywheel to what ever step is required for that specific clutch.
Old Aug 20, 2006 | 04:28 PM
h22silvia's Avatar
Default Re: (chitownrida)
i got the 8lb fidanza with stage 2 6 puck clutch from f1
Old Aug 20, 2006 | 07:15 PM
Mr.Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">If you wanna go and try it, go head. It's your car. But I'll let you know I was one of the guinea pigs for the XTD clutch, and after a year, it's not holding up so well</TD></TR></TABLE>same here, DONT I REPEAT dont use XTD...they suck! I was also a test subject and was good up to like 6 months, and now it starting to slip like crazy
Old Aug 21, 2006 | 06:29 AM
integra15's Avatar
Default Re: (Mr.Luder)
I got a F1 flywheel, it is doing fine (I connot comment on the clutch). Also the machineing on it was quite good when it was new.
Old Aug 21, 2006 | 10:28 PM
hella_usdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">same here, DONT I REPEAT dont use XTD...they suck! I was also a test subject and was good up to like 6 months, and now it starting to slip like crazy</TD></TR></TABLE>
this isn't an xtd clutch, its an F1 brand.
Hows the clutch holding up for those who have one? Would this be better than an exedy stage one?
Old Aug 22, 2006 | 08:09 PM
asmallsol's Avatar
I have this exact package (f1 stage 2 and the fidanza flywheel). I haven't broken it in yet, however, it is a VERY easy combination. IMO the physical weight of the clutch and pressure plate is really heavy, and even with the fidanza flywheel its not as rev happy as I was expecting (primary the weight losed in the flywheel is gained in the clutch)
The pedal is really soft and I kinda wish it was a little firmer. If I get 30-40k miles out of it, i'll be happy.
OrangeTeggy
Aug 18, 2009 08:30 PM
unclematt
May 12, 2007 08:41 AM
teambroken
Feb 6, 2007 08:17 PM
Wazup
13
Mar 30, 2006 12:15 PM
itsmebeaner1987
Sep 15, 2004 09:48 PM
