Does anyone have the total price for a 22 type r sway bar with all parts and BSQ kit?
Search not working again?
1.) 52300-ST7-Z01 rear swaybar ($58.30)
2.) 52315-ST7-Z01 swaybar bushing ($4.40) (2 needed)
3.) 52308-SS0-000 bushing bracket ($5.95) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.75) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($4.90) (4 needed) ?this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($2.45) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.50) (2 needed)
The above is all you need.
BSQ's website: http://geocities.com/bretq/swaybar_install.html
I got the bar itself with the bushings...etc from the Classifieds from a fellow H-T member. Then I bought the BSQ mounting kit from...BSQ.
Overall, it will cost something like $80~$100 depending on where you buy from.
As for where to get it, I'm not sure but try these: http://www.ahmotor.com/ http://www.radleyauto.com/acura/acuraindex.html
is it necessary to buy all those parts or can you just re-use all the old parts (GSR) and buy the ITR "D" brackets and bsq/beaks re-enforcement kit?
The only parts that you don't need to buy are the endlink bushing collars.
For those parts listed, it will cost (as of 6/20/2002):
--$112.55 from A&H Motorsports (http://www.ahmotor.com)
--$97.02 from Acura Carland (http://www.acuraautomotiveparts.net).
Those prices include new endlink bushing collars which are around $4-$5 each.
[Modified by ALF, 5:25 PM 7/7/2002]
those are old prices, they raised up a bit. i just ordered the stuff from A&H and it came out to be about 100 w/ shipping.
*** the bsq kit and its about 120-130 range
I have complete kit for 100 shipped.
This would be good. I think I paid like around $115 for mine total with shipping
lol, I meant 100 shipped for sale.
Check IM!!!!!
[Modified by IgniteTeg, 3:46 AM 7/8/2002]
What is the website?
i work for acura in plano.
sway bar my price is $52 + tax.
i saw the list of parts that I need, but my ? is...
if I buy all those parts, do i still need the bsq?
what is the bsq and what does it do?
thanks in advance from a noob question
There are two reasons why the non-Type-R Integras
require a mounting kit:
1.) The Type-R subframe uses a slightly thicker sheetmetal than the non-Type-R Integras. So the mounting kit is needed to reinforce the subframe sheetmetal.
2.) The Type-R subframe has a flat mounting surface for the swaybar to mount to. Whereas, the non-Type-R Integras have a "stepped" mounting surface which will
not allow the Type-R rear swaybar to be mounted properly. So the mounting kit also provides a flat mounting surface for the swaybar to mount to. Here is a diagram which illustrates this:
[Modified by BSQ, 11:07 AM 7/8/2002]
I just bought the bsq kit.
all i did was click on the paypal thing. is that it?
BTW, I received your order.
I paid $102 from http://www.ahmotor.com a few months ago. BSQ's mounting kit was $20. Using my wonderful math skillz, I get $122.
Not bad at all for a 22mm bar and much improved handling.
schumi
Jun 10, 2003 09:49 AM
roninb18
Apr 3, 2003 11:40 AM
