h22 eg 1/4 et.'s
Old Aug 19, 2006 | 07:10 PM
93civicjaydm's Avatar
Default h22 eg 1/4 et.'s
i recently swapped a jdm h22a into my eg hatch, and took it to the track. It is basically stock, i have the jdm lsd tranny, a short ram intake, 8lb. flywheel and six puck clutch, also have no cat, and greddy catback.
R/T .101
60' 2.399
330 6.236
1/8 9.379
MPH 78.51
1000 12.095
1/4 14.396
MPH 98.12
I'm wondering if this is a decent time, what i should be running, any comments or suggestions please!!!!!!!!!!!!!!! ? ?
Old Aug 20, 2006 | 12:26 AM
2point2's Avatar
Default Re: h22 eg 1/4 et.'s (93civicjaydm)
Is the car is full weight?
If the car is heavy than that's not bad for that 60ft that you got.
Tune the car and get 22" slicks, there's quite a bit of room for improvement.
Old Aug 20, 2006 | 07:08 AM
Default Re: h22 eg 1/4 et.'s (2point2)
suggestions on getting it tuned?
Old Aug 20, 2006 | 07:28 AM
2000_Civic_Si's Avatar
Hey, in my opinion your 60ft. could be around 2.1 or so on street tires, or around 1.8 with slicks. Which would put you at a high 13 with streets and around a mid 13 with slicks. So keep working at it and you will find the best method for your car.
Old Aug 20, 2006 | 08:19 AM
fastwanabe's Avatar
Default Re: h22 eg 1/4 et.'s (2000_Civic_Si)
sounds about right.
Old Aug 20, 2006 | 10:22 AM
2point2's Avatar
Default Re: h22 eg 1/4 et.'s (fastwanabe)
^ 12's.
Old Aug 20, 2006 | 10:27 AM
93.2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
^ 12's. </TD></TR></TABLE>
do eeet
Old Aug 21, 2006 | 02:01 PM
NorthernXposure's Avatar
Default Re: h22 eg 1/4 et.'s (g-wagon)
i ran a 13.5@101 in a eg si hach w/ lsd, intake, 9lb flywheel on drag rads.
Old Aug 21, 2006 | 04:12 PM
amy's Avatar
amy
Default Re: h22 eg 1/4 et.'s (NorthernXposure)
i ran a 65.2 with a 60 ft of about 10.4
Old Aug 21, 2006 | 05:00 PM
Default Re: h22 eg 1/4 et.'s (amy)
has anyone with a h22 eg ever ran at the track without the balance shaft belt on? i was reading in the prelude threads and a couple people said you can free up some power by removing the balance shaft belt. just wondering if there is any truth to that?!
Old Aug 21, 2006 | 05:05 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicjaydm &raquo;</TD></TR><TR><TD CLASS="quote">has anyone with a h22 eg ever ran at the track without the balance shaft belt on? i was reading in the prelude threads and a couple people said you can free up some power by removing the balance shaft belt. just wondering if there is any truth to that?!</TD></TR></TABLE>
yep! check the prelude FAQ.
You could probably spend hours reading about the balance shaft of an H22. I cam to the conclustion that it is useless.. and I regret buying a new belt etc for it.
Old Aug 21, 2006 | 05:38 PM
DC4_MADMAN's Avatar
I ran 13.6 in an EG coupe with no LSD and stock JDM H22 on DRs, I did have a decent suspension though. 2.1-2.2 60fts.
Whats your suspension setup?
Old Aug 21, 2006 | 05:42 PM
Jason-'s Avatar
^12's.
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy &raquo;</TD></TR><TR><TD CLASS="quote">i ran a 65.2 with a 60 ft of about 10.4</TD></TR></TABLE>
lmao!
-Jason
Old Aug 21, 2006 | 06:24 PM
Default Re: (DC4_MADMAN)
suspension wise, i have koni reds all around, skunk 2 coilovers and upper control arms, skunk 2 front upper strut bar, rear j pillar bar, rear skunk 2 upper strut bar, ac lower tie bar, skunk 2 rear sway bar kit. rollin on 15' konig helium ultralights wrapped in 205/50/15 kumhos. i think thats it. i definatley want to get traction bars when i get the money.
Old Aug 21, 2006 | 06:59 PM
v4lu3s's Avatar
RTFM
i did a 13.7@99 on 215/40/17s
did the 1/8 mile at 9.2 on that run
later i ran the 1/8 at 8.5@81mph. wi practice you can hit 13s easily.
93civicjaydm
Aug 21, 2006 06:21 PM
BlownHatch
Mar 7, 2006 09:13 PM
mesonerz
Oct 17, 2004 10:17 AM
SilverDc2
35
Apr 13, 2003 10:03 AM
fastwanabe
17
Mar 27, 2003 08:27 AM
