need help, water leaking into the trunk
just brought a 97 itr one month ago, after a heavy rain today, i found there is water siting under the trunk carpet where my spare tire is. anyone have any idea what/where could cause the leak, or any fix. thx
start pouring buckets of water on top of your car....then investigate where the leak is coming from...how the hell is someone on the internet going to tell you where your leak is....
If it were me, i would gut the interior and sit inside while having someone else take a hose and spray the car and try to look for the leak.
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">If it were me, i would gut the interior and sit inside while having someone else take a hose and spray the car and try to look for the leak.
Ali</TD></TR></TABLE>
Yeah, need to find that ASAP. You don't want water damage.
Just like Yaz said. We had this problem when the taillights were leaking (you could see water inside the taillight lenses). Once we replaced the taillight assemblies, no more water.
I had the taillights out of my '00 ITR, and while cleaning the housings noticed that the foam taillight gaskets had started to crack around the edges. I didn't have any leaks yet, but it was only a matter of time so I replaced em.
Seems like these gaskets start to leak after 6-8 years or so.
drive into a touchless drive thru car wash, hop into the back or stick a friend in the back with the interior panels off and you should find it quick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziantegger10 »</TD></TR><TR><TD CLASS="quote">besides the tail lights theres a drain tube that can come disconnected</TD></TR></TABLE>
i thought that was only with cars with sunroofs
usually the foam gasket is the problem that leads to water in the trunk. You can go to any fabric store or michaels and get 99 cent foam and cut yourself a gasket. The dealers ask for a raping price for those gaskets
worked for me
worked for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegratuner »</TD></TR><TR><TD CLASS="quote">
i thought that was only with cars with sunroofs</TD></TR></TABLE>
they are only there if you have a sunroof.
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrnTurtle »</TD></TR><TR><TD CLASS="quote">usually the foam gasket is the problem that leads to water in the trunk.
The dealers ask for a raping price for those gaskets</TD></TR></TABLE>
Not true. For example, the gaskets (part number 33503-ST7-A01) list for $30.23 each, and Delray Acura sells them for $24.18. That's not a lot of money, especially for knowing that they will fit perfectly, right out of the package (and this is a part that you NEED to fit perfectly, to prevent leaks).
Delicieuxz
23
Nov 13, 2017 09:45 PM
