Clutch pedal VERY stiff
Old Aug 19, 2006 | 12:26 PM
1991civicsi's Avatar
Default Clutch pedal VERY stiff
After installing a new clutch and Heavy Duty pressure plate on my 91' D16A6 I feel the clutch pedal effort is way too stiff for everyday use.
Since this is a cable trans I was wondering if there is anything I could do besides swapping transmissions. (The tranny is freshly rebuilt)
Thanks
Old Aug 19, 2006 | 12:32 PM
robotosan's Avatar
Default Re: Clutch pedal VERY stiff (1991civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991civicsi &raquo;</TD></TR><TR><TD CLASS="quote">After installing a new clutch and Heavy Duty pressure plate on my 91' D16A6 I feel the clutch pedal effort is way too stiff for everyday use.
Thanks</TD></TR></TABLE>
Old Aug 19, 2006 | 12:39 PM
Default Re: Clutch pedal VERY stiff (CRXhf_89)
Ive been told that I could install (with minor fabrication) a cable to hydraulic kit which may soften up the pedal effort.
So, I thought I would ask the Honda guys to see if they had any success with an aftermarket kit.
Old Aug 19, 2006 | 12:46 PM
saaron34's Avatar
I did the same thing (installed a heavy duty unit from ACT) and noticed the cable feel was much more stuff than I was used to. After about a month or so you don't notice it; your leg adapts.
Personally, I would give it some time to see if you can adjust to it before you go looking at throwing parts at it.
Bump for a decent question though: will a "hydraulic kit" mated to a cable transmission help pedal feel? is it even possible?
Old Aug 19, 2006 | 12:52 PM
Default Re: Clutch pedal VERY stiff (saaron34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saaron34 &raquo;</TD></TR><TR><TD CLASS="quote">I did the same thing (installed a heavy duty unit from ACT) and noticed the cable feel was much more stuff than I was used to. After about a month or so you don't notice it; your leg adapts.
That probably explains why I have a slight limp and my left leg appears slightly larger. LOL
Old Aug 19, 2006 | 01:06 PM
SVOboy's Avatar
Don't think the cable to hydro conversion is a minor thing. It's require a new transmission, mounts, and the clutch hydraulics and all that stuff,
Old Aug 19, 2006 | 03:46 PM
blumpfish's Avatar
haha i was thinking about that earlier today when i was driving my friends e-350 , i was ******* around and used my left foot to brake, and nearly sent my friend flying through the windsheild with the slightest effort, i instinctivley used the same amount of force as i would shifting
Wazup
Oct 6, 2008 08:37 PM
DustinM
Mar 25, 2007 11:22 AM
asmallsol
Aug 9, 2004 08:06 AM
GooD moToRs
Jun 27, 2003 02:33 AM
