Parasitic battery drain
Old Aug 19, 2006 | 09:28 AM
oldscoutmaster's Avatar
Default Parasitic battery drain
1995 Accord EX 4 dr - This new car to me has a dead battery after 3-4 days of sitting without starting. Battery and alternator check out OK by Autozone. I put a 12v test lamp between the battery negative post and cable. Test lamp was on, but went out when pulled the interior light fuse. No other fuses turned off the test lamp. Now - if I have the test lamp in place and short the battery and cable with a jumper the test lamp goes out (obviously). But the test lamp does NOT come back on. If I then turn on the interior lights (dome light switch or just open the car door) and then turn off the interior lights, the test lamp STAYS lit.
Ideas or diagnostics will be appreciated! Thanks!
Old Aug 19, 2006 | 11:01 AM
Intense3.2's Avatar
Default Re: Parasitic battery drain (oldscoutmaster)
What are you asking...?
Old Aug 19, 2006 | 12:21 PM
buzz1167's Avatar
Default Re: Parasitic battery drain (Intense2.2)
Sticky relay? Use an Ammeter instead of a test light and tell us how much current is being drawn instead.
Do you have an aftermarket radio or anything like that?
Old Aug 19, 2006 | 04:05 PM
hondadude's Avatar
The door courtsey light is on
Old Aug 19, 2006 | 04:54 PM
jmk64's Avatar
Default Re: Parasitic battery drain (hondadude)
Could be the interior trunk lamp is stuck on. Get in the trunk and close it to see if it goes off. ..................LOL
Old Aug 19, 2006 | 09:05 PM
Intense3.2's Avatar
Default Re: Parasitic battery drain (jmk64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk64 &raquo;</TD></TR><TR><TD CLASS="quote">Could be the interior trunk lamp is stuck on. Get in the trunk and close it to see if it goes off. ..................LOL</TD></TR></TABLE>
lol...
Old Aug 27, 2006 | 04:24 PM
solunderpressure's Avatar
Default Re: Parasitic battery drain (Intense2.2 _Y.T.S._)
im having this same problem........i have a 95 turbo del sol and every problem has not turned up a solution. replaced the battery 3 times, a coolant air relay once, checked all lights inside and even the one in the trunk. i have to get this fixed before i sell the car. if anyone has any solutions or suggestions, please do tell.
Old Aug 27, 2006 | 05:41 PM
Honda-Master's Avatar
http://www.hondaaccordforum.co...m.htm
do it this way
PhoenixDownVII
Aug 26, 2010 11:31 AM
Jediracer
Aug 7, 2010 05:54 PM
johnDX
Nov 18, 2007 01:11 PM
Mr.Speed
Dec 8, 2006 11:43 AM
jkpaul
Sep 11, 2005 10:02 AM
