best way to get crank pulley bolt loose??
Old Aug 19, 2006 | 08:51 AM
xxmastermindxx's Avatar
Default best way to get crank pulley bolt loose??
anybody know? tried air tools and socket with about 5 feet of breaker on it.
also, how can i keep it from moving when im trying to get it off? thanks.
Old Aug 19, 2006 | 09:15 AM
hondaaccord94's Avatar
Default Re: best way to get crank pulley bolt loose?? (xxmastermindxx)
i always use an impact gun but you need some psi behind it.
Old Aug 19, 2006 | 09:22 AM
Default Re: best way to get crank pulley bolt loose?? (hondaaccord94)
yea i was using an impact gun, slightly old though. max psi behind it is about 150 i believe. dont know much about air tools but i can tell its not enough
Old Aug 19, 2006 | 10:02 AM
somewhere on that impact gun you should have an adjustment screw,adjust it on the strongest setting and give it a few tries.
Old Aug 19, 2006 | 10:14 AM
nonvteclude's Avatar
ya your going to nee a bit more ft lbs than that. turn it up as high as you can and go from there
Old Aug 19, 2006 | 11:37 AM
Honda Power's Avatar
if that doesnt work.. you can go to a machine shop, where they have an even more powerful impact gun.
Old Aug 19, 2006 | 04:19 PM
SteveoBA8's Avatar
Default Re: (Integrated Power)
I used my hondy crank pulley holder tool.
Then broke it loose with my 1/2 breakover bar with a 4-5ft cheater bar.
It's a tough sob so keep at it.
Old Aug 19, 2006 | 04:50 PM
marks_lude's Avatar
Default Re: (SteveoBA8)
we tried to get mine off with an impact... wouldnt move, then we put a torch to it for about 3 min and heated it up. came out like a charm.
Old Aug 19, 2006 | 05:05 PM
where can i get said holder tool?
Old Aug 20, 2006 | 11:46 AM
CD7power's Avatar
Default Re: (xxmastermindxx)
http://www.amazon.com/gp/produ...=UTF8
thats where i got mine from. it was a lot cheaper before.
Old Aug 21, 2006 | 05:13 AM
94vtirozguy's Avatar
as mentioned there is a special tool you need. And it needs tobe torqued to 220 lb-ft from memory
Old Aug 21, 2006 | 08:00 AM
daoshao's Avatar
impact wrench works everytime.
Old Aug 21, 2006 | 08:22 AM
98TypeSH's Avatar
Default Re: (daoshao)
It needs to be retorqued to 181 ft lbs. Not 220.... It would be 245 N-m
Old Aug 21, 2006 | 09:29 AM
MadCityLude
Guest
Posts: n/a
Default Re: (98TypeSH)
I have never had a problem with an impact.
Old Aug 22, 2006 | 09:22 PM
AmauryR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx &raquo;</TD></TR><TR><TD CLASS="quote">anybody know? tried air tools and socket with about 5 feet of breaker on it.
also, how can i keep it from moving when im trying to get it off? thanks.</TD></TR></TABLE>
lol, I jus had to deal with that nightmare on my car a few weeks back. I tried 3 airguns, 2 diff compressors, let the bolt soak in PB blaster for few days. Then I got pissed, locked it in 5th gear, had someone stomp the brakes and used a 1/2 drive breaker bar w/ extension and a 5ft steel pipe I had laying around for such occasions. The trick w/ the extension is I used a spare jack stand to support it while I pulled on the bar to break it loose. It'll seem like it's never gonna come off but it will and when it does, try and not bust ur *** on the floor. hth.
-l8r
d124g0n
Oct 29, 2005 07:37 AM
grngsr01
Oct 23, 2005 05:47 AM
Draggin99Si
59
Feb 20, 2005 11:59 AM
flip1199
Nov 12, 2004 06:50 PM
yuckymucky
21
Mar 30, 2003 07:04 PM
