New Clutch installed, Cause change in RPM's for gears and shifting?? H22a4
My prelude had stock Clutch and flywheel. I swapped it to the ACT HA3-XTSS ACT Streetlite Flywheel.
When I used to be able to chirp tires shifting into 2nd. Now I can not. The car shifts completely. Or the chassis for that matter.
Also when I used to race I could ride out the gears until 8,000 and power shift and ride vtec to vtec. I would shift at 8,000 and then be back a 5,500. But now from 1st to second it's 8,000 to 4,800 or 5,000 and it doesn't pull like before.
Is this an install problem or just how it is????
Any info would help.
Probably its due to the lower mass of the lightweight flywheel. It doesnt keep the engine momentum as long.
