distributor king wiring problems
Ok I did a swap on a 88 crx hf and but a obd0 b16 into it. I have code 6 and 9 that wont go away. People from my area said they have had the same thing and replaced the dizzy and both the codes went away. So I went to dizzy king and bought a obd0 b16 dizzy. when I got it and put it on the car started but the codes were still there. I was going to hard wire it in but the dizzy king colors a all Fed up. I went and did alot of searching and this is what I came up with.
Dizzy King................... OBD1.....................OBD0..................... .... Function
yellow/green............Yellow/green.............Large white..................... IMC
Blue.........................blue/green............ blue/green...................... CKPP
blue/yellow...............blue/yellow............blue yellow.......................CKPG
peach/blue...............orange/blue............Orange/blue.....................TDCP
white/blue................white/blue...............white/blue........................TDCG
white........................Orange............... .....orange...........................CYPP
peach.......................white................. .......white.............................CYPG
I got this by looking at the pic here https://honda-tech.com/zerothread?id=1445434 and crossing it with this http://www.boomslang.us/obd0_1.pdf
The code 9 went away but the car wont start. I need some serious help on what to do.
Modified by tgh22a at 11:36 PM 8/18/2006
I got an obd-1 dizzy from distributor king for my d16z6 and doesn't work right. I have to have the distribitor advanced all the way to almost get the base timing I need. When I move it all the way foward it is only showing like 14-15* base when I should be 16.5*
and
NO. IAM NOT OFF A TOOTH.
and
Iron_Forrix
19
Jun 19, 2008 03:58 PM
crexer
21
Dec 11, 2005 10:52 PM
