Suspension & Brakes Theory, alignment, spring rates....
Car bounces ALOT more after installing ST sway bar......
Old Aug 18, 2006 | 03:06 PM
EsCo_EsCo's Avatar
Default Car bounces ALOT more after installing ST sway bar......
I just installed a rear suspension technique sway bar just this past sunday. Ever since then the car has been bouncing alot more ever since. Im stumped right now in what could be the reason why. Any suggestions or help would be appreciated. thnx!
Old Aug 18, 2006 | 03:09 PM
EsCo_EsCo's Avatar
Default Re: Car bounces ALOT more after installing ST sway bar...... (CReX909)
Also forgot to mention that car is lowered about 3" and has Tokico Blue's.
Old Aug 18, 2006 | 03:16 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CReX909 &raquo;</TD></TR><TR><TD CLASS="quote">Also forgot to mention that car is lowered about 3" and has Tokico Blue's.</TD></TR></TABLE>
raise your car up.
Old Aug 18, 2006 | 03:21 PM
EsCo_EsCo's Avatar
Default Re: Car bounces ALOT more after installing ST sway bar...... (Tyson)
thats what i was thinking of but i havent had time to do so. im goin to make time today tho and let u know the results.
Old Aug 18, 2006 | 03:23 PM
Tyson's Avatar
and dont be surprised your shocks are already destroyed.
are you using some egay coilovers with those blues?
Old Aug 18, 2006 | 03:27 PM
EsCo_EsCo's Avatar
ya i know and yea i have some of those coilovers but plan on getting some H&R's or some eibach lower springs.
Old Aug 18, 2006 | 03:30 PM
Tyson's Avatar
well. you just wasted your money.
expect the shocks to be blown.
dont mess with egay coilovers.
when will ppl learn....
btw, put a picture of your swaybar install. im not going to take for granted its installed correctly either.
Modified by Tyson at 4:49 PM 8/18/2006
Old Aug 19, 2006 | 09:00 PM
CRX Lee's Avatar
Tyson is right. That sway bar is probably the only part not contributing to your bouncy ride. Raise the car and hope you have not already destroyed the shcoks but don't be surprised. If you have Brand X cheapo coil-over sleeves, consider getting some proper ones.
Old Aug 20, 2006 | 02:15 AM
CivicFerio's Avatar
Default Re: Car bounces ALOT more after installing ST sway bar...... (CRX Lee)
From my experience testing swaybar bushings for the ASR kits.
Some universal polyurethane swaybar bushings D bracket pinches the bushing. This is apparent while you are bolting them down and seeing the bushing getting squeezed out. This pinches the swaybar so hard that movement is restrained. During dips and bumps on the road it seems like the rear has gained an additional 100lbs spring rates from this. The remedy to this is by adding a few washers between the d bracket and the mounting surface. Hope this helps.
Digitalis
May 21, 2015 09:15 PM
vargas
Suspension & Brakes
May 11, 2008 11:19 AM
MrCivic
Suspension & Brakes
Feb 9, 2008 05:36 PM
JTCdudeman
May 16, 2005 09:40 AM
hialeahzbg
May 13, 2005 10:00 AM
