No sound from speakers . . .
Old Aug 18, 2006 | 12:37 PM
thegeorge613's Avatar
Default No sound from speakers . . .
There's no sound coming from the speakers. The head unit is working fine, power is going to the head unit. There's just no sound coming from the speakers. Anyone know what the problem might be?
Car is a '97 Honda Prelude, BTW.
Old Aug 18, 2006 | 01:55 PM
Odessa's Avatar
Default Re: No sound from speakers . . . (thegeorge613)
All 4 are silent? Maybe your hu's days are over, or maybe it's the acoustic feedback system box acting up. Just some random guesses...
Old Aug 18, 2006 | 03:09 PM
I'm sure it's not the head unit. There's power going to it and it's turning on fine. Thanks anyways.
Anyone else got any suggestions?
Old Aug 18, 2006 | 07:32 PM
bpr0422's Avatar
Default Re: (thegeorge613)
mulitmeter test..
the wire might be damaged..
Old Aug 19, 2006 | 08:14 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegeorge613 &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure it's not the head unit. There's power going to it and it's turning on fine. Thanks anyways.
Anyone else got any suggestions?</TD></TR></TABLE> Just because the HU turns on does not mean it works.
First thing I need to know is is it the stock HU or aftermarket?
Also, if stock, does the AFBU not just control the rear speakers, [question is for Odessa]? 94
Old Aug 19, 2006 | 09:35 AM
Aftermarket HU and CD changer.
Old Aug 19, 2006 | 10:48 AM
fcm's Avatar
fcm
Old Fart
M&M?
If HU lights up and seems to be working, I would check that there is power on both the acc. lead, [red, probably is, as HU lights up] and constant power, [yellow, some HU will work but will have no output if there is no power on the constant lead, power for internal amp] on most Honda/Acura's the constant power is only a 7.5A fuse in under hood fuse box, [not sure where it is on a 97 Lude] do NOT replace the 7.5A with bigger fuse if it is blown, HU constant may need more current then stock constant in radio radio harness was designed to supply, instead run a fused 12ga lead from batt. to behind HU and connect HU constant, [yellow] to it, [just like wiring power for an "off-board" amp]
If power is not the problem, check for a short, [to ground] on any one of the 8 speaker leads, 4 pos.(+) and 4 neg.(-) leads, also check impedance of each speaker, [at HU harness] should be around 4 ohms. 94
HtxPrelude2K
Audio / Security / Video
Sep 2, 2008 06:21 PM
stwano
Jan 8, 2007 10:04 AM
EJ8 GSR-T
Dec 5, 2005 08:54 AM
mpociask
Jun 21, 2004 11:06 AM
Etienne95
May 25, 2004 06:47 AM
