H22A best exhaust systems..............
Old Aug 18, 2006 | 10:29 AM
slammed95lude's Avatar
Default H22A best exhaust systems..............
What is the best exhaust setup on an H22A for power were talking manifold back.
Old Aug 18, 2006 | 10:33 AM
John.'s Avatar
Default Re: H22A best exhaust systems.............. (nyluder)
what are your plans?
Old Aug 18, 2006 | 10:38 AM
Default Re: H22A best exhaust systems.............. (BB1JE)
mild tuning until turbo build at the end of winter, I just got the motor and I want to get the most out of it N/A for a while. Planing on a mild cams, bigger intake manifold, plain old v2 intake and then a good exhaust setup...... and maybe uberdata
Old Aug 18, 2006 | 01:03 PM
Default Re: H22A best exhaust systems.............. (slammed95lude)
Well I decided to go with an Apexi N1 catback again so I can use it when I'm turbo'd thanks for the input
Old Aug 18, 2006 | 01:07 PM
soundbomber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyluder &raquo;</TD></TR><TR><TD CLASS="quote">rsr ex mag.</TD></TR></TABLE>hah, yeah right...
you should just wait until you go turbo to get an exhaust. there's really no point to get a 2.5 inch now and then a 3 inch later. might as well just buy it once.
Old Aug 18, 2006 | 01:31 PM
NazVil86's Avatar
lemme know how that turbo setup turns out for you. i was thinking about keeping my h22a all motor- yaknow mild cam and some tuning. Right now im runnin aem intake- kamikaze headers- and a full catback setup from tanabe- sounds very nice and performs well- dont know how well since no track times on it though, gl.
Old Aug 18, 2006 | 02:40 PM
98vtec's Avatar
moderator emeritus
Default Re: H22A best exhaust systems.............. (Carnage86)
the only companies i know of that make header to muffler exhausts are SMSP,Hytech, and Kteller
Old Aug 18, 2006 | 06:02 PM
Silver Surfer's Avatar
Default Re: H22A best exhaust systems.............. (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">the only companies i know of that make header to muffler exhausts are SMSP,Hytech, and Kteller</TD></TR></TABLE>
or any local exhaust shop
for best performace just send the piping straight back with no bends....doesn't do much for your ground clearance though.
or you can go to kteller.com and buy some mandrel bends and have the shop weld them up to the straight pipe
Old Aug 19, 2006 | 11:29 AM
ilikehonda's Avatar
Default Re: H22A best exhaust systems.............. (Silver Surfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver Surfer &raquo;</TD></TR><TR><TD CLASS="quote">
are you serious???? thats a horrible idea. you want some backpressure with an n/a build. now if its a turbo application then you dont.
Old Aug 19, 2006 | 12:38 PM
98vtec's Avatar
moderator emeritus
Default Re: H22A best exhaust systems.............. (ilikehonda)
i dont want any back pressure. U want exhaust velocity.
Old Aug 19, 2006 | 09:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">
are you serious???? thats a horrible idea. you want some backpressure with an n/a build. now if its a turbo application then you dont.</TD></TR></TABLE>
yeah man, read a little more and post a little less
what you are talking about should not be solved by bends....it should be accounted for in the pipe size. If your piping is to big it will actually slow down the exhaust velocity.
For any type of flow: If you want the smoothest/quickest flow then why would you want it making a turn? But by the same token you have to know how much pressure is in your system....think about water pipes in your house...if they are to large then you don't have enough water pressure in your shower.
This is one of the reasons people heat wrap their header....to raise the temp and increase the rate of flow
Old Aug 19, 2006 | 09:12 PM
Mykizism's Avatar
and this is the guy running the obx lsd....
Old Aug 19, 2006 | 09:51 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed95lude &raquo;</TD></TR><TR><TD CLASS="quote">mild tuning until turbo build at the end of winter, I just got the motor and I want to get the most out of it N/A for a while. Planing on a mild cams, bigger intake manifold, plain old v2 intake and then a good exhaust setup...... and maybe uberdata</TD></TR></TABLE>
HAHAHAHAHAHA!!! Man, so many of you guys crack me up, it's not even funny. Actually, it is sad.
You get a big from me.
Old Aug 20, 2006 | 07:26 AM
h22 civic's Avatar
Default Re: H22A best exhaust systems.............. (AndyD)
3" k teller
Old Aug 20, 2006 | 05:26 PM
admedlin's Avatar
I have a pretty good exhaust on mine if you like it quiet. Apexi RS
Old Aug 20, 2006 | 08:52 PM
petern101's Avatar
Default Re: (admedlin)
the best exhaust is no exhaust
/sarcasm
Old Aug 21, 2006 | 01:22 AM
vtecbasher's Avatar
Skunk2 for N/A set-up.
A little loud, but certainly works for me.
Old Aug 21, 2006 | 05:09 AM
OFFdutyHERO's Avatar
Default Re: H22A best exhaust systems.............. (vtecbasher)
does anyone have good vid/sound clip of an rsr or apexi exhaust??
Old Aug 21, 2006 | 06:23 AM
integra15's Avatar
That is out of production.
Old Aug 21, 2006 | 03:02 PM
taisho's Avatar
i want a mugen twinloop ;[ its soo damn expensive...
::shakes fist::
Old Aug 21, 2006 | 04:53 PM
the mugen twin loop uses 2.25" piping.......not the best for performance
Old Aug 21, 2006 | 10:38 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">are you serious???? thats a horrible idea. you want some backpressure with an n/a build. now if its a turbo application then you dont.</TD></TR></TABLE>
shut your face dude, what the hell do you know
ever heard of open header?? makes more power na.....dont talk out of your ***, it makes you into one
Old Aug 21, 2006 | 11:34 PM
98vtec's Avatar
moderator emeritus
Default Re: H22A best exhaust systems.............. (mgags7)
w3rd 2 yOuR m07h3r
Old Oct 8, 2006 | 05:27 PM
andre809_lude's Avatar
Default Re: H22A best exhaust systems.............. (bb4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">shut your face dude, what the hell do you know
ever heard of open header?? makes more power na.....dont talk out of your ***, it makes you into one </TD></TR></TABLE>
nuhh hes talkin about the bottom torque.. cuzz if you have no back pressure youll loose the bottom torque.. but the top will grow big time...
i think thats what he was comming at....i donnow..
less flow - good for bottom end, kills the top
higher flow - looses in the bottom but, crazy good for top end
correct me if im wrong.....
Old Oct 8, 2006 | 05:55 PM
K-Spec's Avatar
This is one of the reasons people heat wrap their header....to raise the temp and increase the rate of flow</TD></TR></TABLE>
is that true? i've also heard that when you wrap it, it could crack the header because it gets too hot.
