Arias & SRP Pistons -2 sets of Eagle Rods - 70MM Edelbrock TB - AEM FPR - D16 Head - D15 Block - Cam
Well I have a bunch of stuff I need to get rid of. All these things are best offer.
Set of USED 10:1 SRP Pistons and Eagle Rods. Thee rods are for a B16 and the pistons are stock bore (81mm)
I would seperate. Looking for $200 for each shipped.
Perfect B16A2 crank. It was in my drag car when I cracked a sleeve. The crank is in perfect shape. It only has 20 miles on it tops. It was just micropolished. $60 plus shipping.
Edelbrock 70 MM throttle body and adapter plate. $225 Shipped
D16Y7 Head Perfect Shape <100,000 miles $50
CX motor. 80,000 Miles. Runs perfect. $50
Also have some A/C stuff. Best offer.
D16 Cam Gear. It is an OBX-R cam gear. Had it on my built single cam such a long time ago. I replace the allen screws with bigger ones. It is a good piece. $50 shipped.
More pictures can be taken of just about anything.
I might have a DSM BOV for sale in a couple days as well.
I also have a B16A2 block that was just rehoned and setup to run the 81mm pistons. The crank just got micropolished and speced as well. I am looking for $200 for the block and crank. It is in perfect shape.
9:1 Arias Pistons with a skirt coating and eagle H-beam rods. They were in my block with the cracked sleeve, but are still usable. The ringlands were not touched, the piston that was in the cracked sleeve has a little bit of scuffing on it, but it is not bad. Looking for $425 shipped for this setup. (Pistons are 81.5mm and Rods are for a B16)
That is the damage to the piston. If you run your finger across the scuffs they can't be felt. I beliefe it just took the coating off the piston.
boostontheD
Jan 10, 2012 04:12 PM
turbotypeR@SPEC
Dec 8, 2011 05:25 AM
93turbo16
Aug 31, 2006 09:08 AM
dynomax27
May 31, 2004 08:57 PM
good guy!
