DA sway into a crx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boston’s_rex »</TD></TR><TR><TD CLASS="quote">yes a b18a1 will fit but it will not be plug and play</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HFpower »</TD></TR><TR><TD CLASS="quote">would DA sways fit on a 91 crxHF?</TD></TR></TABLE>
Yes the front sway should just bolt on no problem, I belive the rear might be a different story, I don't think the HF had a rear sway and don't have the mount for it...I may be wrong..if you have the mount then you can make it bolt on, I believe by switching the mounts to opposite sides
you wouldnt want to put the DA front sway on because it will cause understeer. For the rear your going to need new lower control arms and fab up some mounts like thishttps://honda-tech.com/zerothread?id=1146145
OUT OF ORDER ROB
Jun 14, 2006 11:51 PM
