pressure plate torque specs
Old Aug 17, 2006 | 05:45 PM
sikcrx80's Avatar
Default pressure plate torque specs
i am just installing a clutch and just wondering what the torque spec are..
Old Aug 17, 2006 | 05:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: pressure plate torque specs (sikcrx80)
80-something I think, just a little higher than the wheel lug nuts if I remember from replacing my brother's del Sol clutch just last week. Put a breaker bar or something on the crank pulley bolt to keep the engine from rotating while you tighten the bolts.
Old Aug 17, 2006 | 06:09 PM
PrinceAli132's Avatar
Default Re: pressure plate torque specs (PatrickGSR94)
I just did mine yesterday and the helms recommends 19lbf-ft. They flywheel was at 76lbf-ft.
Ill post a pic of the helm's manual in a minute.
Ali
Dartanian's Avatar
Default Re: pressure plate torque specs (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">I just did mine yesterday and the helms recommends 19lbf-ft. They flywheel was at 76lbf-ft.
Ali</TD></TR></TABLE>
Old Aug 17, 2006 | 06:12 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">80-something I think, just a little higher than the wheel lug nuts if I remember from replacing my brother's del Sol clutch just last week. Put a breaker bar or something on the crank pulley bolt to keep the engine from rotating while you tighten the bolts.</TD></TR></TABLE>
80lb.ft on pressure plate bolts? no..
19lf.ft is the correct spec
Default Re: pressure plate torque specs (Sleeper Style)
Sorry for the crappy fast pic, but im eating right now so i really didn't car too much. Don't forget to tighten in a criss-cross pattern.
Ali
Old Aug 17, 2006 | 07:28 PM
Community Builder
ah doh! my bad, I was thinking flywheel... yes I remember know how much of a PITA it was to tighten the flywheel bolts to 80+ lb-ft. w/ those little shorty heads on them. Busted knuckles FTL
snzh22
Jun 13, 2008 01:06 AM
1QwIkEf
Sep 9, 2007 09:07 PM
InvaderTrax
Oct 12, 2006 07:19 AM
Ben18C
Apr 21, 2004 03:06 PM
Benny Z
Oct 14, 2003 05:19 PM
