Broken bolts.
Old Aug 17, 2006 | 04:11 PM
akademikz26's Avatar
Default Broken bolts.
Any suggestion of how to extract a broken strut and header bolt? What's the best way to take it out and what tool should I use?
Old Aug 18, 2006 | 05:05 AM
200cs's Avatar
Default Re: Broken bolts. (akademikz26)
If there are threads left on the stud then use two nuts and tighten them into each other at this point you can just srew out the stud using the nut closest to the block to turn it.
If it is broken in the head then it will have to be drilled and then use an easy-out to screw it out. You will want to center puch it first as the fastener is harder that the block and you do not want the drill to "walk" over into the block. If the stud is broken jagged like a mountain top then use a sander to make it flat before you center punch it. You might also want to consider getting some left handed drill bits as these will often remove it for you.
I have removed several using both methods and both work fine however, if you are uncomfortable with it you may want to take it to a machine shop and have them do it.....
Old Aug 18, 2006 | 08:25 AM
94rs-turbo's Avatar
all you can do is get someone with a tap set to help u out
AllMadness
Jul 18, 2014 02:29 PM
EDCorey
Oct 22, 2011 03:39 PM
sammyb20
Mar 1, 2009 07:30 PM
jorge59la
Jun 18, 2008 02:57 PM
