92 accord starting issue (no Spark)
Old Aug 17, 2006 | 01:44 PM
branicvw's Avatar
Default 92 accord starting issue (no Spark)
Hi Guys its a 92 accord, 5spd. replaced the main relay becuase of a hot start issue and it was ok for a bit. was at a traffic light one day had AC on and the car started running funny almost like it started missing.. turned off AC rolled down windows and car just died. Now car doesnt seem to have spark just keeps turning over.. I replaced the coil and still no spark. I havent checked to see if its getting fuel yet but am gonna give it a shot tonight. just wanted to post up and see if anyone has any ideas. Car seems to turn over fine, ingition relay under the hood isnt blown. Any ideas at all??
Old Aug 17, 2006 | 04:49 PM
hondadude's Avatar
Default Re: 92 accord starting issue (branicvw)
Sounds like the ignitor in the dist. decided to kick the bucket. Check to be sure you have battery voltage at the Black/yellow wire at the coil, so you know the ignition switch is outting out.
Old Aug 17, 2006 | 06:12 PM
branicvw's Avatar
Default Re: 92 accord starting issue (hondadude)
ok i will check the voltage at the coil. Thanks. Also i did check and the car is def getting fuel. I am gonna open up the timing cover this weekend and check if the tbelt is ok.. it sounds kinda hollow to me when it turns over now since it shut down that day. You think maybe the cam position sensor or crank sensor could be bad? Wouldnt that not let the coil fire if it couldnt tell were cyl 1 is at all times?
Old Aug 17, 2006 | 06:14 PM
branicvw's Avatar
Actually come to think of it i am checking for spark on the main lead from the coil so that is before the distributor. Wouldnt i still get spark there if it was the ignitor in the distrib???
Old Aug 18, 2006 | 10:53 AM
hondadude's Avatar
nope, you won't get spark from the coil if the ignitor is bad
mete4d
Jan 19, 2018 12:23 PM
hometheaterman
Feb 21, 2012 06:56 PM
xhopesfall24
Jan 20, 2011 02:28 PM
92_Accord_LX
Nov 13, 2009 05:13 PM
banshee4
Dec 21, 2007 06:19 AM
